Update broadcast domain properties
Updates the properties of a broadcast domain to change its configuration settings within the network environment. Use this endpoint to modify attributes such as the broadcast domain name or network ports, ensuring the network meets your specific requirements.
HTTP method and endpoint
PATCH /network/ethernet/broadcast-domains/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network port broadcast-domain modify -
network port broadcast-domain rename -
network port broadcast-domain move
uuid |
string |
path |
True |
Broadcast domain UUID |
Request Body
| Name | Type | Description |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
mtu |
integer |
Maximum transmission unit, largest packet size on this network |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
ports |
array[ports] |
Ports that belong to the broadcast domain |
uuid |
string |
Example request
"ipspace": {
"name": "exchange",
"mtu": 1500,
"name": "bd1",
"ports": [
"name": "e1b",
"node": {
"name": "node1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376484 |
Cannot change the MTU of a VLAN to be greater than the MTU of the port hosting it. |
1377267 |
The specified IPspace does not exist. |
1377269 |
Failed to lookup the specified IPspace. |
1377560 |
Broadcast domain already exists in specified IPspace. |
1377575 |
Remove associated subnets before deleting this broadcast domain. |
1377605 |
Moving the system-generated broadcast domain to another IPspace is not supported. |
1966460 |
The specified MTU is either too large or too small. |
1967082 |
The specified ipspace.name does not match the IPspace name of ipspace.uuid. |
1967150 |
The specified ipspace.uuid is not valid. |
1967151 |
The specified ipspace.uuid and ipspace.name do not match. |
1967152 |
Patching IPspace for a broadcast domain requires an effective cluster version of 9.7 or later. |
53280884 |
The MTU of the broadcast domain cannot be modified on this platform. |
53282013 |
Broadcast domain cannot be renamed because the name is reserved by the system. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
node
name |
string |
Name of node on which the port is located. |
ports
Port UUID along with readable names
name |
string |
node |
uuid |
string |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
ipspace |
mtu |
integer |
name |
string |
ports |
array[ports] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
