REST API reference
Updates the properties of a broadcast domain
  • network port broadcast-domain rename
learn more
  • [doc /network/ethernet/broadcast-domains](#docs-networking-network_ethernet_broadcast-domains)
PATCH /network/ethernet/broadcast-domains/{uuid}
Updates the properties of a broadcast domain.
  • network port broadcast-domain modify
uuid
string
path
True
Broadcast domain UUID
Request Body
Name Type Description
_links
_links
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
mtu
integer
Maximum transmission unit, largest packet size on this network
name
string
Name of the broadcast domain, scoped to its IPspace
ports
array[ports]
Ports that belong to the broadcast domain
uuid
string
Example request
      "href": "/api/resourcelink"
  "ipspace": {
    "name": "exchange",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1967082
The specified ipspace.name does not match the IPspace name of ipspace.uuid.
1377267
The specified IPspace does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ipspace
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
node
name
string
Name of node on which the port is located.
ports
Port UUID along with readable names
_links
_links
name
string
node
node
uuid
string
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links
_links
ipspace
ipspace
mtu
integer
name
string
ports
array[ports]
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
