Update broadcast domain properties
PATCH /network/ethernet/broadcast-domains/{uuid}
Updates the properties of a broadcast domain.
Related ONTAP commands
network port broadcast-domain modify -
network port broadcast-domain rename
Learn more
uuid  |
string  |
path  |
True  |
Broadcast domain UUID  |
Request Body
| Name | Type | Description |
_links  |
ipspace  |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.  |
mtu  |
integer  |
Maximum transmission unit, largest packet size on this network  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
ports  |
array[ports]  |
Ports that belong to the broadcast domain  |
uuid  |
string  |
Example request
      "href": "/api/resourcelink"
  "ipspace": {
    "name": "exchange",
  "mtu": 1500,
  "name": "bd1",
  "ports": [
      "name": "e1b",
      "node": {
        "name": "node1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377267  |
The specified IPspace does not exist.  |
1377269  |
Failed to lookup the specified IPspace.  |
1377560  |
Broadcast domain already exists in specified IPspace.  |
1377605  |
Moving the system-generated broadcast domain to another IPspace is not supported.  |
1967082  |
The specified ipspace.name does not match the IPspace name of ipspace.uuid.  |
1967150  |
The specified ipspace.uuid is not valid.  |
1967151  |
The specified ipspace.uuid and ipspace.name do not match.  |
1967152  |
Patching IPspace for a broadcast domain requires an effective cluster version of 9.7 or later.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ipspace
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
node
name  |
string  |
Name of node on which the port is located.  |
ports
Port UUID along with readable names
_links  |
name  |
string  |
node  |
uuid  |
string  |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links  |
ipspace  |
mtu  |
integer  |
name  |
string  |
ports  |
array[ports]  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
