REST API reference
Update an IP interface
Updates an IP interface to modify its configuration or properties. This operation is typically used to adjust network settings or enhance connectivity.
HTTP method and endpoint
PATCH /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface migrate
  • network interface modify
  • network interface rename
  • network interface revert
uuid
string
path
True
IP interface UUID
Request Body
Name Type Description
ddns_enabled
boolean
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false.
dns_zone
string
Fully qualified DNS zone name
enabled
boolean
The administrative state of the interface.
fail_if_subnet_conflicts
boolean
This command fails if the specified IP address falls within the address range of a named subnet. Set this value to false to use the specified IP address and to assign the subnet owning that address to the interface.
ip
ip_info
IP information
location
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
name
string
Interface name
rdma_protocols
array[string]
Supported RDMA offload protocols
service_policy
service_policy
services
array[string]
The services associated with the interface.
state
string
The operational state of the interface.
subnet
ip_subnet_reference
A named subnet. Either UUID or name can be supplied on input.
uuid
string
The UUID that uniquely identifies the interface.
Example request
  "dns_zone": "storage.company.com",
  "ip": {
    "address": "10.10.10.7",
    "netmask": "24"
  "location": {
    "failover": "string",
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "dataLif1",
  "rdma_protocols": [
    "roce"
  "service_policy": {
    "name": "default-intercluster",
  "services": [
    "data_nfs"
  "state": "string",
  "subnet": {
    "name": "subnet1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vip": true
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262196
Field cannot be set in this operation.
1376663
Cannot add interface to DNS zone because all interfaces from a single DNS zone must be in the same SVM.
1376963
Duplicate IP address.
1376976
The specified port is not capable of hosting this LIF.
1376986
The interface could not migrate because no additional interfaces can be hosted on the specified node.
1376997
Interface failed to migrate because the node hosting the port is not healthy.
1376998
The specified location.node does not own any ports in the same broadcast domain as the home port of the interface.
1376999
Interface failed to migrate because port is in the down admin state.
1377607
The specified location.port is not in the same broadcast domain as the home port of the interface.
1377666
Subnet does not have any addresses available.
1966081
Failed to lookup the port on the node.
1966133
The netmask cannot represent the entire IP subnet.
1966135
Cluster configuration can only be changed from node where the cluster LIF resides.
1966138
The same IP address may not be used for both a mgmt interface and a gateway address.
1966141
Invalid DNS zone name.
1966142
Only data LIFs can be assigned a DNS zone.
1966191
The interface could not be created because interface identifier creation failed.
1966197
Migration of cluster interfaces must be done from the local node.
1966238
Cannot change the home-node or home-port of an active SAN or NVMe data interface.
1966267
IPv6 addresses must have a prefix length between 1 and 127.
1966269
IPv4 addresses must have a prefix length between 1 and 32.
1966299
Changing a cluster LIF's administrative status to down is not a supported operation.
1966419
Subnet not found in the IPspace of the SVM.
1966419
Specified subnet not found in the IPspace of the LIF.
1966476
DNS Update is supported only on data interfaces.
1966477
DNS Update is supported only on interfaces configured with the NFS or CIFS protocol.
1966507
A port on the node has been identified as potentially unhealthy.
1966685
There are no ports on the node that are in the broadcast domain associated with the IPspace.
1967106
The specified location.home_port.name does not match the specified port name of location.home_port.uuid.
1967107
The specified location.home_port.uuid is not valid.
1967111
A home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field.
1967113
The specified location.port.name does not match the port name of location.port.uuid.
1967114
The specified location.port.uuid is not valid.
1967115
The specified location.node.name does not match the node name of location.node.uuid.
1967116
The specified location.port.node.name does not match the node name of location.node.uuid.
1967117
The specified location.port.node.name does not match location.node.name.
1967118
A node must be specified by at least one location.node or location.port field.
1967119
The specified location.node.name does not match the node name of location.port.uuid.
1967120
The specified service_policy.name does not match the specified service policy name of service_policy.uuid.
1967121
The specified service_policy.uuid is not valid.
1967125
You cannot patch the "location.node" or "location.port" fields to migrate interfaces using the iSCSI data protocol. Instead perform the following PATCH operations on the interface: set the "enabled" field to "false"; change one or more "location.home_port" fields to migrate the interface; and then set the "enabled" field to "true".
1967129
1967130
The specified location.home_port.name is not valid.
1967131
The specified location.home_port.uuid and location.home_port.name are not valid.
1967132
1967133
The specified location.port.name is not valid.
1967134
The specified location.port.uuid and location.port.name are not valid.
1967138
Cannot patch port for a VIP interface. The specified parameter location.port.uuid is not valid.
1967139
Cannot patch port for a VIP interface. The specified parameter location.port.name is not valid.
1967140
Cannot patch port for a VIP interface. The specified parameters location.port.uuid and location.port.name are not valid.
1967141
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.uuid is not valid.
1967142
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.name is not valid.
1967143
Cannot patch home_port for a VIP interface. The specified parameters location.home_port.uuid and location.home_port.name are not valid.
1967145
The specified location.failover is not valid.
1967153
No suitable port exists on location.home_node to host the interface.
1967380
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.node.name is not valid. Consider using location.home_node.name instead.
1967385
VIP interface address and netmask error.
1967386
Cannot patch port for a VIP interface. The specified parameter location.port.node.name is not valid. Consider using location.node.name instead.
1967387
The specified IP address is in use by a subnet in this IPspace.
1967389
Patching location.is_home to the value "false" is not supported. The value "true" would revert a network interface to its home port if the current value is "false".
1967390
Cannot patch a LIF revert as it requires an effective cluster version of 9.9.1 or later.
1967391
Patching the DNS zone requires an effective cluster version of 9.9.1 or later.
1967392
Patching the DDNS enable parameter requires an effective cluster version of 9.9.1 or later.
1967396
The specified subnet.name does not match the subnet name of subnet.uuid.
1967397
The specified subnet.uuid does not match any configured subnet.";
1967398
Address must be specified by either ip.address and ip.netmask, or at least one subnet field, not both.";
2621574
This operation is not permitted on an SVM that is configured as the destination of a MetroCluster SVM relationship.
53281018
Failover policy is not compatible with one or more services in service policy
53281065
The service_policy does not exist in the SVM.
53281072
The failover policy is not valid for interfaces in the SVM.
53281086
LIF would exceed the maximum number of supported intercluster LIFs in IPspace.
53281087
SVM must have an NVMe service to perform this operation.
53281089
LIF on SVM cannot be updated to use service policy because that service policy includes SAN services and the target LIF is not home.
53281096
LIF could not be modified because the current port does not support the specified rdma-protocols.
53281106
Failed checking the cluster capabilities.
53281109
The interface could not be updated to use the service policy because the interface is currently associated with BGP peer group.
53281111
Cannot update the service policy because the interface is associated with a BGP peer-group.
53281113
Configuration details for LIF were modified but an error was encountered while updating the LIF's operational status.
53281114
The specified parameter is only supported on data SVMs.
string
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
name
string
IPspace name
uuid
string
IPspace UUID
broadcast_domain
Broadcast domain UUID along with a readable name.
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
home_node
name
string
uuid
string
node
name
string
Name of node on which the port is located.
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name
string
node
node
uuid
string
node
name
string
uuid
string
port
name
string
node
node
uuid
string
location
auto_revert
boolean
failover
string
Policy that defines where an interface is permitted to move on failover. The policy named “default” implements the recommended best practice for NAS LIFs on the current platform and cluster, and was known as “system_defined” in the CLI.
home_node
home_node
home_port
home_port
is_home
boolean
node
node
port
port
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the interface.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
service_policy
name
string
uuid
string
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the interface.
status
string
throughput_raw
throughput_raw
timestamp
string
ip_subnet_reference
name
string
The name of the subnet. If only the name is provided, the IPspace scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the subnet.
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
name
string
uuid
string
ip_interface
ddns_enabled
boolean
dns_zone
string
enabled
boolean
boolean
ip
ip_info
IP information
location
location
name
string
Interface name
rdma_protocols
array[string]
service_policy
service_policy
services
array[string]
state
string
subnet
ip_subnet_reference
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
