REST API reference
Update an IP interface
Updates an IP interface to change its configuration settings, which is useful when you need to modify network properties or migrate the interface to a different location within your network infrastructure.
HTTP method and endpoint
PATCH /network/ip/interfaces/{uuid}
Introduced in
ONTAP 9.6
  • network interface migrate
  • network interface modify
  • network interface rename
  • network interface revert
uuid
string
path
True
IP interface UUID
Request Body
Name Type Description
ddns_enabled
boolean
Indicates whether or not dynamic DNS updates are enabled. Defaults to true if the interface supports "data_nfs" or "data_cifs" services, otherwise false.
dns_zone
string
Fully qualified DNS zone name
enabled
boolean
The administrative state of the interface.
ip
ip_info
IP information
location
location
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. For PATCH, set is_home to true to revert a LIF back to its home port.
name
string
Interface name
service_policy
service_policy
services
array[string]
The services associated with the interface.
state
string
The operational state of the interface.
uuid
string
The UUID that uniquely identifies the interface.
Example request
  "dns_zone": "storage.company.com",
  "ip": {
    "address": "10.10.10.7",
    "netmask": "24"
  "location": {
    "failover": "string",
    "home_node": {
      "name": "node1",
    "home_port": {
      "name": "e1b",
      "node": {
        "name": "node1"
    "node": {
      "name": "node1",
    "port": {
      "name": "e1b",
      "node": {
        "name": "node1"
  "name": "dataLif1",
  "service_policy": {
    "name": "default-intercluster",
  "services": [
    "data_nfs"
  "state": "string",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vip": null
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1376963
Duplicate IP address.
1376997
Interface failed to migrate because the node hosting the port is not healthy.
1376998
The specified location.node does not own any ports in the same broadcast domain as the home port of the interface.
1377607
The specified location.port is not in the same broadcast domain as the home port of the interface.
1966138
The same IP address may not be used for both a mgmt interface and a gateway address.
1966141
Invalid DNS zone name.
1966142
Only data LIFs can be assigned a DNS zone.
1966267
IPv6 addresses must have a prefix length between 1 and 127.
1966269
IPv4 addresses must have a prefix length between 1 and 32.
1967106
The specified location.home_port.name does not match the specified port name of location.home_port.uuid.
1967107
The specified location.home_port.uuid is not valid.
1967111
A home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field.
1967113
The specified location.port.name does not match the port name of location.port.uuid.
1967114
The specified location.port.uuid is not valid.
1967115
The specified location.node.name does not match the node name of location.node.uuid.
1967116
The specified location.port.node.name does not match the node name of location.node.uuid.
1967117
The specified location.port.node.name does not match location.node.name.
1967118
A node must be specified by at least one location.node or location.port field.
1967119
The specified location.node.name does not match the node name of location.port.uuid.
1967120
The specified service_policy.name does not match the specified service policy name of service_policy.uuid.
1967121
The specified service_policy.uuid is not valid.
1967125
You cannot patch the "location.node" or "location.port" fields to migrate interfaces using the iSCSI data protocol. Instead perform the following PATCH operations on the interface: set the "enabled" field to "false"; change one or more "location.home_port" fields to migrate the interface; and then set the "enabled" field to "true".
1967129
1967130
The specified location.home_port.name is not valid.
1967131
The specified location.home_port.uuid and location.home_port.name are not valid.
1967132
1967133
The specified location.port.name is not valid.
1967134
The specified location.port.uuid and location.port.name are not valid.
1967138
Cannot patch port for a VIP interface. The specified parameter location.port.uuid is not valid.
1967139
Cannot patch port for a VIP interface. The specified parameter location.port.name is not valid.
1967140
Cannot patch port for a VIP interface. The specified parameters location.port.uuid and location.port.name are not valid.
1967141
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.uuid is not valid.
1967142
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.name is not valid.
1967143
Cannot patch home_port for a VIP interface. The specified parameters location.home_port.uuid and location.home_port.name are not valid.
1967145
The specified location.failover is not valid.
1967153
No suitable port exists on location.home_node to host the interface.
1967380
Cannot patch home_port for a VIP interface. The specified parameter location.home_port.node.name is not valid. Consider using location.home_node.name instead.
1967386
Cannot patch port for a VIP interface. The specified parameter location.port.node.name is not valid. Consider using location.node.name instead.
1967387
The specified IP address is in use by a subnet in this IPspace.
1967389
Cannot patch a LIF revert. The specified parameter location.is_home
1967390
Cannot patch a LIF revert as it requires an effective cluster version of 9.9.1 or later.
1967391
Patching the DNS zone requires an effective cluster version of 9.9.1 or later.
1967392
Patching the DDNS enable parameter requires an effective cluster version of 9.9.1 or later.
53281065
The service_policy does not exist in the SVM.
53281086
LIF would exceed the maximum number of supported intercluster LIFs in IPspace.
string
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
name
string
IPspace name
uuid
string
IPspace UUID
broadcast_domain
Broadcast domain UUID along with a readable name.
name
string
Name of the broadcast domain, scoped to its IPspace
uuid
string
home_node
name
string
uuid
string
node
name
string
Name of node on which the port is located.
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
name
string
node
node
uuid
string
node
name
string
uuid
string
port
name
string
node
node
uuid
string
location
auto_revert
boolean
failover
string
Defines where an interface may failover.
home_node
home_node
home_port
home_port
is_home
boolean
node
node
port
port
throughput
The rate of throughput bytes per second observed at the interface.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
metric
The most recent sample of I/O metrics for the interface.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
service_policy
name
string
uuid
string
throughput_raw
Throughput bytes observed at the interface. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the interface.
status
string
throughput_raw
throughput_raw
timestamp
string
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
name
string
The name of the SVM.
uuid
string
ip_interface
ddns_enabled
boolean
dns_zone
string
enabled
boolean
ip
ip_info
IP information
location
location
name
string
Interface name
service_policy
service_policy
services
array[string]
state
string
uuid
string
