REST API reference
Modify an Active Directory account for an SVM
Updates the Active Directory account for a specific SVM, which may be necessary to change account settings or credentials. This operation is asynchronous, and you can track progress through the provided Task UUID and Link.
HTTP method and endpoint
PATCH /protocols/active-directory/{svm.uuid}
Introduced in
ONTAP 9.12
Usage notes
Modifies the Active Directory account for a given SVM.
  • vserver active-directory modify
Important notes
  • Patching Active Directory account is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
svm.uuid
string
path
True
Request Body
Name Type Description
discovered_servers
array[discovered_servers]
Specifies the discovered servers records.
force_account_overwrite
boolean
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused.
fqdn
string
Fully qualified domain name.
password
string
Administrator password required for Active Directory account creation, modification and deletion.
preferred_dcs
array[preferred_dcs]
Specifies the preferred domain controller (DC) records.
username
string
Administrator username required for Active Directory account creation, modification and deletion.
Example request
  "discovered_servers": [
      "domain": "server1.com",
      "node": {
        "name": "node1",
      "preference": "preferred",
      "server": {
        "ip": "7.4.3.1",
        "name": "scspk0659102001",
        "type": "kerberos"
      "state": "ok"
  "force_account_overwrite": "",
  "fqdn": "server1.com",
  "password": "testpwd",
  "preferred_dcs": [
  "username": "admin"
Status: 200, Ok
discovered_servers
boolean
fqdn
string
password
string
preferred_dcs
username
string
      "node": {
        "name": "node1",
      "server": {
        "ip": "7.4.3.1",
        "type": "kerberos"
      "state": "ok"
  "preferred_dcs": [
  "username": "admin"
Status: Default
ONTAP Error Response Codes
Error Code Description
656464
Failed to modify the Active Directory machine account. Reason: Invalid Credentials.
656465
Failed to create the Active Directory machine account. Reason: An account with this name already exists.
656466
Failed to create the Active Directory machine account. Reason: Unable to connect to any domain controllers.
656467
Failed to modify the Active Directory machine account. Reason: Organizational-Unit not found.
656478
Failed to create the Active Directory machine account. Reason: KDC has no support for encryption type.
string
node
name
string
uuid
string
active_directory_discovered_server_reference
ip
string
The IP address of the server that was discovered.
name
string
Server Name
type
string
The type of the server that was discovered.
discovered_servers
domain
string
The Active Directory domain that the discovered server is a member of.
node
node
preference
string
The preference level of the server that was discovered.
server
state
string
The status of the connection to the server that was discovered.
preferred_dcs
svm
name
string
uuid
string
active_directory
discovered_servers
boolean
fqdn
string
password
string
preferred_dcs
username
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
