Modify an Active Directory account for an SVM
PATCH /protocols/active-directory/{svm.uuid}
Introduced In: 9.12
Modifies the Active Directory account for a given SVM.
Related ONTAP commands
vserver active-directory modify -
vserver cifs security modify
Important notes
Patching Active Directory account is asynchronous. Response contains Task UUID and Link that can be queried to get the status.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
discovered_servers |
array[discovered_servers] |
Specifies the discovered servers records. |
force_account_overwrite |
boolean |
If set to true and a machine account exists with the same name as specified in "name" in Active Directory, it will be overwritten and reused. |
fqdn |
string |
Fully qualified domain name. |
password |
string |
Administrator password required for Active Directory account creation, modification and deletion. |
preferred_dcs |
array[preferred_dcs] |
Specifies the preferred domain controller (DC) records. |
security |
username |
string |
Administrator username required for Active Directory account creation, modification and deletion. |
Example request
"discovered_servers": [
"domain": "server1.com",
"node": {
"name": "node1",
"preference": "preferred",
"server": {
"ip": "7.4.3.1",
"name": "scspk0659102001",
"type": "kerberos"
"state": "ok"
"force_account_overwrite": "",
"fqdn": "server1.com",
"password": "testpwd",
"security": {
"advertised_kdc_encryptions": [
"string"
"username": "admin"
Status: 200, Ok
boolean |
fqdn |
string |
password |
string |
preferred_dcs |
security |
username |
string |
"node": {
"name": "node1",
"server": {
"ip": "7.4.3.1",
"type": "kerberos"
"state": "ok"
"security": {
"string"
"username": "admin"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
656464 |
Failed to modify the Active Directory machine account. Reason: Invalid Credentials. |
656465 |
Failed to create the Active Directory machine account. Reason: An account with this name already exists. |
656466 |
Failed to create the Active Directory machine account. Reason: Unable to connect to any domain controllers. |
656467 |
Failed to modify the Active Directory machine account. Reason: Organizational-Unit not found. |
656478 |
Failed to create the Active Directory machine account. Reason: KDC has no support for encryption type. |
656490 |
Unable to modify the Active Directory account. The Active Directory account name is already used by another SVM. |
656495 |
Failed to update Active Directory security settings for SVM. |
656496 |
Failed to update Active Directory security settings for SVM. Reason: KDC has no support for encryption type. |
href |
string |
_links
node
name |
string |
uuid |
string |
active_directory_discovered_server_reference
ip |
string |
The IP address of the server that was discovered. |
name |
string |
Server Name |
type |
string |
The type of the server that was discovered. |
discovered_servers
domain |
string |
The Active Directory domain that the discovered server is a member of. |
node |
preference |
string |
The preference level of the server that was discovered. |
server |
state |
string |
The status of the connection to the server that was discovered. |
preferred_dcs
active_directory_security
advertised_kdc_encryptions |
array[string] |
svm
name |
string |
uuid |
string |
active_directory
boolean |
fqdn |
string |
password |
string |
preferred_dcs |
security |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
