Update NDMP configuration for an SVM
PATCH /protocols/ndmp/svms/{svm.uuid}
Introduced In: 9.7
Updates the NDMP configuration for a specific SVM.
Related ONTAP commands
vserver services ndmp modify
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
Request Body
| Name | Type | Description |
authentication_types |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled on the SVM? |
svm |
Example request
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"svm": {
"name": "svm1",
Status: 200, Ok
array[string] |
enabled |
boolean |
svm |
"plaintext",
"challenge"
"enabled": 1,
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
65601536 |
The operation is not supported because NDMP SVM-aware mode is disabled. |
65601551 |
Authentication type "plaintext_sso" cannot be combined with other authentication types. |
href |
string |
_links
svm
name |
string |
uuid |
string |
ndmp_svm
array[string] |
enabled |
boolean |
svm |
