REST API reference
Update NDMP configuration for an SVM
Updates the NDMP configuration for a specific SVM to modify its settings as needed.
HTTP method and endpoint
PATCH /protocols/ndmp/svms/{svm.uuid}
Introduced in
ONTAP 9.7
  • vserver services ndmp modify
svm.uuid
string
path
True
SVM UUID
Request Body
Name Type Description
authentication_types
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled on the SVM?
svm
svm
Example request
  "authentication_types": [
    "plaintext",
    "challenge"
  "enabled": 1,
  "svm": {
    "name": "svm1",
Status: 200, Ok
array[string]
enabled
boolean
svm
svm
    "plaintext",
    "challenge"
  "enabled": 1,
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
65601536
The operation is not supported because NDMP SVM-aware mode is disabled.
65601551
Authentication type "plaintext_sso" cannot be combined with other authentication types.
string
svm
name
string
uuid
string
ndmp_svm
array[string]
enabled
boolean
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
