REST API reference
Manage NDMP configuration of SVM
Manage NDMP configurations of SVMs to control data movement and ensure efficient backup operations within your ONTAP environment. Use these endpoints to update settings such as authentication types and enablement status.
You can use this API to manage NDMP configurations of SVMs.
Updates the "enabled" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"enabled":"false"}'
Updates the "authentication_types" field:
 PATCH "/api/protocols/ndmp/svms/9b372ce7-3a4b-11e9-a7f8-0050568e3d73" '{"authentication_types":["challenge"]}'
