Update the properties of an export policy rule
PATCH /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced In: 9.6
Updates the properties of an export policy rule to change an export policy rule's index or fields.
Related ONTAP commands
vserver export-policy rule modify -
vserver export-policy rule setindex
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
new_index |
integer |
query |
False |
New Export Rule Index |
Request Body
| Name | Type | Description |
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
Example request
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704054 |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-" |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
3277000 |
Upgrade all nodes to ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules |
3277083 |
User ID is not valid. Enter a value for User ID from 0 to 4294967295 |
3277149 |
The "Anon" field cannot be an empty string |
href |
string |
_links
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
name |
string |
uuid |
string |
export_rule
boolean |
allow_suid |
boolean |
anonymous_user |
string |
chown_mode |
string |
clients |
index |
integer |
string |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
rw_rule |
array[string] |
superuser |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
