Update the properties of an export policy rule
Updates the properties of an export policy rule to modify its index or fields, enabling adjustments to the access control settings for NFS exports.
HTTP method and endpoint
PATCH /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced in
ONTAP 9.6
Usage notes
Updates the properties of an export policy rule to change an export policy rule's index or fields.
Related ONTAP commands
vserver export-policy rule modify -
vserver export-policy rule setindex
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
new_index |
integer |
query |
False |
New Export Rule Index |
Request Body
| Name | Type | Description |
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
Example request
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262196 |
Field 'svm.name' is not supported in the body of PATCH request |
262197 |
The value provided is invalid for the field |
262203 |
Field 'svm.uuid' is not supported in the body of PATCH request |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704054 |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-" |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
3277000 |
Upgrade all nodes to ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules |
3277083 |
User ID is not valid. Enter a value for User ID from 0 to 4294967295 |
3277149 |
The "Anon" field cannot be an empty string |
6691623 |
User is not authorized |
href |
string |
_links
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
name |
string |
uuid |
string |
export_rule
boolean |
allow_suid |
boolean |
anonymous_user |
string |
chown_mode |
string |
clients |
index |
integer |
string |
protocols |
array[string] |
ro_rule |
array[string] |
rw_rule |
array[string] |
superuser |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
