Update the Vscan configuration for an SVM
PATCH /protocols/vscan/{svm.uuid}
Introduced In: 9.6
Updates the Vscan configuration of an SVM. Allows you to either enable or disable a Vscan, and allows you to clear the Vscan cache that stores the past scanning data for an SVM.
Important note:
The Vscan PATCH endpoint does not allow you to modify scanner-pools, On-Demand policies or On-Access policies. Those modifications can only be done through their respective endpoints.
Related ONTAP commands
vserver vscan enable -
vserver vscan disable -
vserver vscan reset
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
cache_clear |
boolean |
Discards the cached information of the files that have been successfully scanned. Once the cache is cleared, files are scanned again when they are accessed. PATCH only |
enabled |
boolean |
Specifies whether or not Vscan is enabled on the SVM. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027015 |
Attempting to enable a Vscan but no active scanner-pool exists for the specified SVM |
10027009 |
Attempting to enable a Vscan for an SVM for which it's already enabled |
10027010 |
Attempting to disable a Vscan for an SVM for which it's already disabled |
10027011 |
Attempting to enable a Vscan for an SVM for which no CIFS server exists |
10027023 |
Attempting to enable a Vscan for an SVM for which no active Vscan On-Access policy exists |
10027012 |
Cannot enable Vscan on an administrative SVM. |
href |
string |
_links
scope
exclude_extensions |
array[string] |
List of file extensions for which scanning is not performed. |
exclude_paths |
array[string] |
List of file paths for which scanning must not be performed. |
include_extensions |
array[string] |
List of file extensions to be scanned. |
max_file_size |
integer |
Maximum file size, in bytes, allowed for scanning. |
only_execute_access |
boolean |
Scan only files opened with execute-access. |
scan_readonly_volumes |
boolean |
Specifies whether or not read-only volume can be scanned. |
scan_without_extension |
boolean |
Specifies whether or not files without any extension can be scanned. |
vscan_on_access
An On-Access policy that defines the scope of an On-Access scan. Use On-Access scanning to check for viruses when clients open, read, rename, or close files over CIFS. By default, ONTAP creates an On-Access policy named "default_CIFS" and enables it for all the SVMs in a cluster.
enabled |
boolean |
Status of the On-Access Vscan policy |
mandatory |
boolean |
Specifies if scanning is mandatory. File access is denied if there are no external virus-scanning servers available for virus scanning. |
scope |
schedule
Schedule of the task.
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
scope
array[string] |
exclude_paths |
array[string] |
array[string] |
max_file_size |
integer |
boolean |
vscan_on_demand_policy
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path |
string |
The path from the Vserver root where the task report is created. |
scan_paths |
array[string] |
List of paths that need to be scanned. |
schedule |
Schedule of the task. |
scope |
cluster_reference
name |
string |
uuid |
string |
scanner_pool
Scanner pool is a set of attributes which are used to validate and manage connections between clustered ONTAP and external virus-scanning server, or "Vscan server".
cluster |
privileged_users |
array[string] |
Specifies a list of privileged users. A valid form of privileged user-name is "domain-name\user-name". Privileged user-names are stored and treated as case-insensitive strings. Virus scanners must use one of the registered privileged users for connecting to clustered Data ONTAP for exchanging virus-scanning protocol messages and to access file for scanning, remedying and quarantining operations.
role |
string |
Specifies the role of the scanner pool. The possible values are:
servers |
array[string] |
Specifies a list of IP addresses or FQDN for each Vscan server host names which are allowed to connect to clustered ONTAP.
svm
name |
string |
uuid |
string |
vscan
Vscan can be used to protect data from being compromised by viruses or other malicious code. This combines best-in-class third-party antivirus software with ONTAP features that give you the flexibility you need to control which files get scanned and when. Storage systems offload scanning operations to external servers hosting antivirus software from thirdparty vendors. An Antivirus Connector on the external server handles communications between the storage system and the antivirus software.
cache_clear |
boolean |
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
