REST API reference
Update the Google Cloud KMS configuration
Updates the Google Cloud KMS configuration to change the settings and credentials used for securing your data with Google Cloud's Key Management Service. This action typically follows changes in your security requirements or when rotating credentials for enhanced security.
HTTP method and endpoint
PATCH /security/gcp-kms/{uuid}
Introduced in
ONTAP 9.9
Optional properties
  • application_credentials - New credentials used to verify the application's identity to the Google Cloud KMS.
  • proxy_type - Type of proxy (http/https) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • port - Authorization server and Google Cloud KMS port number.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • project_id - Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS.
  • key_ring_name - Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS.
  • key_ring_location - Google Cloud KMS key ring location.
  • cloudkms_host - Google Cloud KMS host subdomain.
  • oauth_host - Open authorization server host name.
  • oauth_url - Open authorization URL for the access token.
  • verify_host - Verify the identity of the Google Cloud KMS host name.
  • `verify_ip ` - Verify identity of Google Cloud KMS IP address.
  • privileged_account - Account used to impersonate Google Cloud KMS requests.
  • security key-manager external gcp update-credentials
  • security key-manager external gcp update-config
uuid
string
path
True
Google Cloud KMS UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
string
Google Cloud application's service account credentials required to access the specified KMS. It is a JSON file containing an email address and the private key of the service account holder.
caller_account
string
Google Cloud KMS caller account email
cloudkms_host
string
ekmip_reachability
array[ekmip_reachability]
google_reachability
google_reachability
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
oauth_host
string
oauth_url
string
port
integer
privileged_account
string
Google Cloud KMS account to impersonate.
proxy_host
string
Proxy host name.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
uuid
string
A unique identifier for the Google Cloud KMS.
verify_host
boolean
verify_ip
boolean
Verify the identity of the Google Cloud KMS IP address.
Example request
  "application_credentials": "{ type: service_account, project_id: project-id, private_key_id: key-id, private_key: -----BEGIN PRIVATE KEY-----\nprivate-key\n-----END PRIVATE KEY-----\n, client_email: service-account-email, client_id: client-id, auth_uri: https://accounts.google.com/o/oauth2/auth, token_uri: https://accounts.google.com/o/oauth2/token, auth_provider_x509_cert_url: https://www.googleapis.com/oauth2/v1/certs, client_x509_cert_url: https://www.googleapis.com/robot/v1/metadata/x509/service-account-email }",
  "caller_account": "myaccount@myproject.com",
  "cloudkms_host": "cloudkms.googleapis.com",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "google_reachability": {
    "code": "346758",
    "message": "Google Cloud KMS is not reachable from all nodes - <reason>."
  "oauth_host": "oauth2.googleapis.com",
  "oauth_url": "https://oauth2.googleapis.com/token",
  "port": 443,
  "privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "code": "346758",
    "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537541
No inputs were provided for the patch request.
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537605
Failed to establish connectivity with the cloud key management service.
65537713
Internal Error. Failed to store the application credentials.
65537714
The "application_credentials" field must be specified.
65537721
The Google Cloud Key Management Service is not configured for the SVM.
65537724
Failed to update the Google Cloud Key Management Service because invalid application credentials were provided.
65537732
ONTAP 9.9.1 does not allow modification of the following fields, "project_id", "key_ring_name" and "key_ring_location".
string
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
google_reachability
code
string
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster.
message
string
Set to the error message when 'reachable' is false.
reachable
boolean
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster.
state
cluster_state
boolean
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster.
code
string
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
name
string
uuid
string
gcp_kms
_links
_links
string
caller_account
string
cloudkms_host
string
ekmip_reachability
google_reachability
google_reachability
oauth_host
string
oauth_url
string
port
integer
privileged_account
string
proxy_host
string
Proxy host name.
proxy_password
string
proxy_port
integer
Proxy port number.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
state
state
uuid
string
verify_host
boolean
verify_ip
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
