Update the Google Cloud KMS configuration
Updates the Google Cloud KMS configuration to modify settings related to key management and access control within your ONTAP environment. Use this operation when you need to adjust authentication methods, proxy settings, or project-specific parameters for secure interactions with Google Cloud KMS.
HTTP method and endpoint
PATCH /security/gcp-kms/{uuid}
Introduced in
ONTAP 9.9
Optional properties
application_credentials- New credentials used to verify the application's identity to the Google Cloud KMS. -
proxy_type- Type of proxy (http/https) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
port- Authorization server and Google Cloud KMS port number. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used. -
project_id- Google Cloud project (application) ID of the deployed Google Cloud application with appropriate access to the Google Cloud KMS. -
key_ring_name- Google Cloud KMS key ring name of the deployed Google Cloud application with appropriate access to the specified Google Cloud KMS. -
key_ring_location- Google Cloud KMS key ring location. -
cloudkms_host- Google Cloud KMS host subdomain. -
oauth_host- Open authorization server host name. -
oauth_url- Open authorization URL for the access token. -
verify_host- Verify the identity of the Google Cloud KMS host name. -
`verify_ip ` - Verify identity of Google Cloud KMS IP address.
privileged_account- Account used to impersonate Google Cloud KMS requests. -
authentication_method- The authentication method to use for retrieving short lived authentication tokens. -
gce_metadata_server- A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when theauthentication_methodis set tosa_credentials_attachment.
Related ONTAP commands
security key-manager external gcp update-credentials -
security key-manager external gcp update-config
uuid |
string |
path |
True |
Google Cloud KMS UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_links |
application_credentials |
string |
The Google Cloud application's service account credentials required to access the specified KMS. The client_email and private_key fields of the service account holder are required. The credentials are required if the |
authentication_method |
string |
Google Cloud KMS authentication method. |
caller_account |
string |
Google Cloud KMS caller account email |
cloudkms_host |
string |
Google Cloud KMS host subdomain. |
ekmip_reachability |
array[ekmip_reachability] |
gce_metadata_server |
string |
A custom metadata server URL used for retrieving short lived authentication tokens if the default service account is not used. This is only applicable when the |
google_reachability |
Indicates whether or not the Google Cloud KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
oauth_host |
string |
Open authorization server host name. |
oauth_url |
string |
Open authorization URL for the access token. |
port |
integer |
Authorization server and Google Cloud KMS port number. |
privileged_account |
string |
Google Cloud KMS account to impersonate. |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port number. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
state |
Google Cloud Key Management Services is a cloud key management service (KMS) that provides a secure store for encryption keys. This object indicates whether or not the Google Cloud KMS key protection is available on all nodes in the cluster.
uuid |
string |
A unique identifier for the Google Cloud KMS. |
verify_host |
boolean |
Verify the identity of the Google Cloud KMS host name. |
verify_ip |
boolean |
Verify the identity of the Google Cloud KMS IP address. |
Example request
"application_credentials": "{\"private_key\":\"ValidPrivateKey\",\"client_email\":\"my@account.email.com\"}",
"authentication_method": "application_credentials_key",
"caller_account": "myaccount@myproject.com",
"cloudkms_host": "cloudkms.googleapis.com",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"gce_metadata_server": "http://169.254.169.254/computeMetadata/v1/instance/service-accounts/default/token",
"google_reachability": {
"code": "346758",
"message": "Google Cloud KMS is not reachable from all nodes - <reason>."
"oauth_host": "oauth2.googleapis.com",
"oauth_url": "https://oauth2.googleapis.com/token",
"port": 443,
"privileged_account": "myserviceaccount@myproject.iam.gserviceaccount.com",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"scope": "string",
"state": {
"code": "346758",
"message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537541 |
No inputs were provided for the patch request. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537605 |
Failed to establish connectivity with the cloud key management service. |
65537713 |
Internal Error. Failed to store the application credentials. |
65537714 |
The "application_credentials" field must be specified. |
65537721 |
The Google Cloud Key Management Service is not configured for the SVM. |
65537724 |
Failed to update the Google Cloud Key Management Service because invalid application credentials were provided. |
65537732 |
ONTAP 9.9.1 does not allow modification of the following fields, "project_id", "key_ring_name" and "key_ring_location". |
href |
string |
_links
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
google_reachability
code |
string |
Code corresponding to the error message. Returns a 0 if Google Cloud KMS is reachable from all nodes in the cluster. |
message |
string |
Set to the error message when 'reachable' is false. |
reachable |
boolean |
Set to true if the Google Cloud KMS is reachable from all nodes of the cluster. |
state
cluster_state |
boolean |
Set to true when Google Cloud KMS key protection is available on all nodes of the cluster. |
code |
string |
Error code corresponding to the status message. Returns 0 if Google Cloud KMS key protection is available in all nodes of the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
uuid |
string |
gcp_kms
_links |
string |
string |
caller_account |
string |
cloudkms_host |
string |
string |
oauth_host |
string |
oauth_url |
string |
port |
integer |
string |
proxy_host |
string |
Proxy host name. |
proxy_password |
string |
proxy_port |
integer |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
scope |
string |
state |
uuid |
string |
verify_host |
boolean |
verify_ip |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
