REST API reference
Update a cloud store
Updates the specified cloud store with new configuration details. This operation initiates a job and provides you with a link to track its progress.
HTTP method and endpoint
PATCH /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the cloud store specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
  • storage aggregate object-store modify
aggregate.uuid
string
path
True
Aggregate UUID
target.uuid
string
path
True
Cloud target UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
availability
string
Availability of the object store.
availability_at_partner
string
Availability of the object store at the HA partner.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
resync-progress
integer
Resync progress of the mirror object store in percentage.
unavailable_reason
unavailable_reason
unreclaimed_space_threshold
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
Example request
  "availability": "string",
  "availability_at_partner": "string",
  "resync-progress": 0,
  "unavailable_reason": {
    "message": "string"
  "unreclaimed_space_threshold": 20,
  "used": 0
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
787154
The Object stores are currently not synchronized. Check the mirror resync status.
787156
Modifying the attributes of a mirror object store is not allowed.
string
aggregate
Aggregate
name
string
target
Cloud target
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
cloud_store
availability
string
string
mirror_degraded
boolean
primary
boolean
resync-progress
integer
unavailable_reason
unavailable_reason
integer
used
integer
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
