Update a cloud store
PATCH /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Introduced In: 9.6
Updates the cloud store specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store modify
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
target.uuid |
string |
path |
True |
Cloud target UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
availability |
string |
Availability of the object store. |
mirror_degraded |
boolean |
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool. |
primary |
boolean |
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool. |
resync-progress |
integer |
Resync progress of the mirror object store in percentage. |
unavailable_reason |
unreclaimed_space_threshold |
integer |
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST. |
used |
integer |
The amount of object space used. Calculated every 5 minutes and cached. |
Example request
"availability": "string",
"resync-progress": 0,
"unavailable_reason": {
"message": "string"
"unreclaimed_space_threshold": 20,
"used": 0
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787154 |
The Object stores are currently not synchronized. Check the mirror resync status. |
787156 |
Modifying the attributes of a mirror object store is not allowed. |
href |
string |
_links
aggregate
Aggregate
name |
string |
target
Cloud target
name |
string |
uuid |
string |
message |
string |
Indicates why the object store is unavailable. |
cloud_store
availability |
string |
mirror_degraded |
boolean |
primary |
boolean |
resync-progress |
integer |
integer |
used |
integer |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
