Update a cloud store
PATCH /storage/aggregates/{aggregate.uuid}/cloud-stores/{target.uuid}
Updates the cloud store specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store modify
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
target.uuid |
string |
path |
True |
Cloud target UUID |
Request Body
| Name | Type | Description |
_links |
availability |
string |
Availability of the object store. |
mirror_degraded |
boolean |
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool. |
primary |
boolean |
This field indicates whether the cloud store is the primary cloud store of a cloud mirrored composite aggregate. |
unreclaimed_space_threshold |
integer |
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST. |
used |
integer |
The amount of object space used. Calculated every 5 minutes and cached. |
Example request
"href": "/api/resourcelink"
"availability": "string",
"unreclaimed_space_threshold": 20,
"used": 0
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
target
Cloud target
_links |
name |
string |
uuid |
string |
cloud_store
_links |
availability |
string |
mirror_degraded |
boolean |
primary |
boolean |
integer |
used |
integer |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
