Modify origin options for a Flexcache origin volume in the cluster
Modifies the origin options for a Flexcache origin volume in the cluster. This is useful for adjusting configuration settings specific to your storage needs.
HTTP method and endpoint
PATCH /storage/flexcache/origins/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Modifies origin options for a origin volume in the cluster.
Required properties
uuid- Origin volume UUID. -
block_level_invalidation- Value for the Block Level Invalidation flag - options {true\|false}.
Related ONTAP commands
volume flexcache origin config modify
Learn more
uuid |
string |
path |
True |
Unique identifier of the origin of the FlexCache volume. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
block_level_invalidation |
boolean |
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the computational cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation. |
global_file_locking_enabled |
boolean |
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume. |
name |
string |
Origin volume name |
uuid |
string |
Origin volume UUID. Unique identifier for origin of FlexCache. |
Example request
"name": "vol1, vol_2",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846870 |
Either origin volume uuid or BLI option value is missing |
66847020 |
Failed to get origin volume details using volume uuid |
66847021 |
Failed to modify origin volume options |
href |
string |
_links
cluster
name |
string |
uuid |
string |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
flexcache_relationship
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
volume |
svm
Origin volume SVM
name |
string |
uuid |
string |
flexcache_origin
Defines the origin endpoint of FlexCache.
boolean |
boolean |
name |
string |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
