REST API reference
Modify origin options for a Flexcache origin volume in the cluster
Modifies the origin options for a Flexcache origin volume in a cluster. This enables you to adjust specific settings that affect the behavior and management of the origin volume.
HTTP method and endpoint
PATCH /storage/flexcache/origins/{uuid}
Introduced in
ONTAP 9.9
Usage notes
Modifies origin options for a origin volume in the cluster.
Required properties
  • uuid - Origin volume UUID.
  • block_level_invalidation - Value for the Block Level Invalidation flag - options {true\|false}.
  • volume flexcache origin config modify
uuid
string
path
True
Unique identifier of the origin of the FlexCache volume.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
boolean
Block level invalidation enables the FlexCache volume to retain blocks that are not changed at the FlexCache volume without having to evict them. This means that the FlexCache volume does not have to again incur the computational cost of fetching blocks over the WAN from the FlexCache volume origin on the next client access. Block level invalidation is a property of the origin volume. Without block level invalidation, any write at the origin volume would evict the whole file at the FlexCache volume, since by default, origin volume does a file level invalidation.
global_file_locking_enabled
boolean
Specifies whether a global file locking option is enabled for an origin volume of a FlexCache volume.
uuid
string
Origin volume UUID. Unique identifier for origin of FlexCache.
Example request
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563512"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
66846870
Either origin volume uuid or BLI option value is missing
66847020
Failed to get origin volume details using volume uuid
66847021
Failed to modify origin volume options
string
cluster
name
string
uuid
string
svm
name
string
uuid
string
volume
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
flexcache_relationship
cluster
cluster
create_time
string
Creation time of the relationship.
ip_address
string
Cluster management IP of the remote cluster.
size
integer
Size of the remote volume.
state
string
Volume state
volume
volume
svm
Origin volume SVM
name
string
uuid
string
flexcache_origin
Defines the origin endpoint of FlexCache.
boolean
boolean
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
