REST API reference
Update a QoS option
PATCH /storage/qos/qos-options
Introduced In: 9.14
Update a specific QoS option. This option is available only at diagnostic privilege level and above.
  • qos settings cluster-options modify
Request Body
Name Type Description
background_task_reserve
integer
Percentage reserve for critical background tasks.
Example request
  "background_task_reserve": 33
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
8454377
This command is not supported on this platform.
8454378
Unsupported value specified for background-task-reserve. Supported values are 0 to 99.
string
qos_option
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
