Update a QoS option
Updates a specific QoS option to modify its configuration. This operation is available at the diagnostic privilege level and above.
HTTP method and endpoint
PATCH /storage/qos/qos-options
Introduced in
ONTAP 9.14
Usage notes
Update a specific QoS option. This option is available only at diagnostic privilege level and above.
Related ONTAP commands
qos settings cluster-options modify
Request Body
| Name | Type | Description |
background_task_reserve |
integer |
Percentage reserve for critical background tasks. |
Example request
"background_task_reserve": 33
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454377 |
This command is not supported on this platform. |
8454378 |
Unsupported value specified for background-task-reserve. Supported values are 0 to 99. |
href |
string |
_links
qos_option
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
