Update a Snapshot copy policy
Updates a Snapshot copy policy to modify its parameters or schedule, ensuring that your data protection strategy aligns with your current requirements.
HTTP method and endpoint
PATCH /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Related ONTAP commands
snapshot policy modify -
snapshot policy modify-schedule -
snapshot policy add-schedule
Learn more
uuid |
string |
path |
True |
Snapshot copy policy UUID |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the Snapshot copy policy. |
enabled |
boolean |
Is the Snapshot copy policy enabled? |
scope |
string |
Set to "svm" when the request is on a data SVM, otherwise set to "cluster". |
uuid |
string |
Example request
"comment": "string",
"enabled": 1,
"scope": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Code
| Error Code | Description |
1638414 |
Cannot enable policy. Reason: Schedule not found. |
href |
string |
_links
schedule
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
copies
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
retention_period |
string |
The retention period of Snapshot copies for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
svm
name |
string |
uuid |
string |
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
comment |
string |
enabled |
boolean |
scope |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
