REST API reference
Create a new DR group in a MetroCluster IP configuration
Creates a new disaster recovery group within a MetroCluster IP configuration. This operation is essential when setting up or expanding your MetroCluster environment to ensure data redundancy and high availability.
HTTP method and endpoint
POST /cluster/metrocluster/dr-groups
Introduced in
ONTAP 9.8
Usage notes
Creates a new DR group in the MetroCluster over IP configuration.
Required properties
  • partner_cluster.name
  • dr_pairs
  • mccip_ports
  • metrocluster configuration-settings dr-group create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
dr_pairs
array[dr_pair]
id
integer
DR Group ID
mccip_ports
array[mccip_ports]
List of Port specifications.
partner_cluster
partner_cluster
Partner cluster information.
Example request
  "dr_pairs": [
      "node": {
        "name": "node1",
      "partner": {
        "name": "node1",
  "id": 0,
  "mccip_ports": [
      "l3_config": {
        "ipv4_interface": {
          "address": "10.10.10.7",
          "gateway": "10.1.1.1",
          "netmask": "24"
      "name": "e1b",
      "node": {
        "name": "node1",
      "uuid": "string",
      "vlan_id": 200
  "partner_cluster": {
    "name": "cluster1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2430034
Node "node" is not found in partner cluster "cluster". Use the "cluster show" command on the partner cluster to see the list of valid node names.
2430060
The DR group cannot be created while node "node" on cluster "cluster" is configured for MetroCluster.
2432833
Operation is already running.
2432836
There are not enough disks in Pool1. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2432840
Configuring DR Groups
2432841
Generating IP addresses
2432844
Checking remote storage pool
2432845
Mirroring aggregates
2432846
Configuring MetroCluster and DR mirroring
2432857
Adding new MetroCluster DR Group
2432858
MetroCluster DR Group setup done
string
node
Local node of the DR Group.
name
string
uuid
string
partner
Partner node of the DR Group.
name
string
uuid
string
dr_pair
node
node
partner
partner
ipv4_interface
Object to setup an interface along with its default router.
address
string
IPv4 or IPv6 address
gateway
string
The IPv4 or IPv6 address of the default router.
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
l3_config
ipv4_interface
ipv4_interface
node
Node information
name
string
uuid
string
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config
l3_config
name
string
Port name
node
node
Node information
uuid
string
Port UUID
vlan_id
integer
VLAN ID
partner_cluster
name
string
uuid
string
metrocluster_dr_group
DR group information.
dr_pairs
array[dr_pair]
id
integer
DR Group ID
mccip_ports
array[mccip_ports]
partner_cluster
partner_cluster
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
