Create a new DR group in a MetroCluster IP configuration
POST /cluster/metrocluster/dr-groups
Introduced In: 9.8
Creates a new DR group in the MetroCluster over IP configuration.
Required properties
partner_cluster.name -
dr_pairs
Recommended optional properties
mccip_ports
Learn more
Related ONTAP commands
metrocluster configuration-settings dr-group create
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
dr_pairs |
array[dr_pair] |
id |
integer |
DR Group ID |
mccip_ports |
array[mccip_ports] |
List of Port specifications. |
partner_cluster |
Partner cluster information. |
Example request
"dr_pairs": [
"node": {
"name": "node1",
"partner": {
"name": "node1",
"id": 0,
"mccip_ports": [
"l3_config": {
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"name": "e1b",
"node": {
"name": "node1",
"uuid": "string",
"vlan_id": 200
"partner_cluster": {
"name": "cluster1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2430034 |
Node "node" is not found in partner cluster "cluster". Use the "cluster show" command on the partner cluster to see the list of valid node names. |
2430060 |
The DR group cannot be created while node "node" on cluster "cluster" is configured for MetroCluster. |
2432833 |
Operation is already running. |
2432836 |
There are not enough disks in Pool1. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2432840 |
Configuring DR Groups |
2432841 |
Generating IP addresses |
2432844 |
Checking remote storage pool |
2432845 |
Mirroring aggregates |
2432846 |
Configuring MetroCluster and DR mirroring |
2432857 |
Adding new MetroCluster DR Group |
2432858 |
MetroCluster DR Group setup done |
href |
string |
self_link
_links
node
Local node of the DR Group.
name |
string |
uuid |
string |
partner
Partner node of the DR Group.
name |
string |
uuid |
string |
dr_pair
node |
Local node of the DR Group. |
partner |
Partner node of the DR Group. |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
IPv4 or IPv6 address |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
l3_config
ipv4_interface |
Object to setup an interface along with its default router. |
node
Node information
name |
string |
uuid |
string |
mccip_ports
Port configuration specification. l3_config information is only needed when configuring a MetroCluster IP for use in a layer 3 network.
l3_config |
name |
string |
Port name |
node |
Node information |
uuid |
string |
Port UUID |
vlan_id |
integer |
VLAN ID |
partner_cluster
name |
string |
uuid |
string |
metrocluster_dr_group
DR group information.
dr_pairs |
array[dr_pair] |
id |
integer |
DR Group ID |
mccip_ports |
partner_cluster |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
