REST API reference
Create the NIS domain and server configuration for a data SVM
Configures an NIS domain and server settings for a data SVM to establish network information services integration. This setup facilitates centralized authentication and management for client systems within the domain.
HTTP method and endpoint
POST /name-services/nis
Introduced in
ONTAP 9.6
Usage notes
Creates an NIS domain and server confguration for a data SVM. NIS configuration for the cluster is managed via /api/security/authentication/cluster/nis .
Important notes
  • Each SVM can have one NIS domain configuration.
  • Multiple SVMs can be configured with the same NIS domain. Specify the NIS domain and NIS servers as input.Domain name and servers fields cannot be empty.
  • Both FQDNs and IP addresses are supported for the servers field.
  • IPv6 must be enabled if IPv6 family addresses are specified in the servers field.
  • A maximum of ten NIS servers are supported.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the NIS configuration.
  • domain - NIS domain to which the configuration belongs.
  • servers - List of NIS server IP addresses.
  • vserver services name-service nis-domain create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
binding_details
array[binding_details]
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field.
bound_servers
array[string]
domain
string
The NIS domain to which this configuration belongs.
servers
array[string]
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.
svm
svm
Example request
  "binding_details": [
      "server": "string",
      "status": {
        "code": "string",
        "message": "string"
  "bound_servers": [
    "string"
  "domain": "domainA.example.com",
  "servers": [
    "10.10.10.10",
    "example.com"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of NIS domain records.
records
array[nis_service]
  "num_records": 1,
  "records": [
          "server": "string",
          "status": {
            "code": "string",
            "message": "string"
      "bound_servers": [
        "string"
      "servers": [
        "10.10.10.10",
        "example.com"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1966253
IPv6 is not enabled in the cluster
2621488
Invalid SVM context
2621706
The specified SVM UUID is incorrect for the specified SVM name
3276964
NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters
3276933
A maximum of 10 NIS servers can be configured per SVM
13434916
The SVM is in the process of being created. Wait a few minutes, and then try the command again.
23724109
DNS resolution failed for one or more specified servers
23724112
DNS resolution failed due to an internal error. Contact technical support if this issue persists
23724132
DNS resolution failed for all the specified servers
23724130
Cannot use an IPv6 name server address because there are no IPv6 LIFs
string
binding_status
code
string
Code corresponding to the server's binding status.
message
string
Detailed description of the server's binding status.
binding_details
server
string
Hostname/IP address of the NIS server in the domain.
status
binding_status
svm
name
string
uuid
string
nis_service
binding_details
bound_servers
array[string]
domain
string
servers
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
