Create the NIS domain and server configuration for a data SVM
POST /name-services/nis
Introduced In: 9.6
Creates an NIS domain and server configuration for a data SVM. NIS configuration for the cluster is managed via /api/security/authentication/cluster/nis .
Important notes
Each SVM can have one NIS domain configuration.
Multiple SVMs can be configured with the same NIS domain. Specify the NIS domain and NIS servers as input.Domain name and servers fields cannot be empty.
Both FQDNs and IP addresses are supported for the servers field.
IPv6 must be enabled if IPv6 family addresses are specified in the servers field.
A maximum of ten NIS servers are supported.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the NIS configuration. -
domain- NIS domain to which the configuration belongs. -
servers- List of NIS server IP addresses.
Related ONTAP commands
vserver services name-service nis-domain create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
binding_details |
array[binding_details] |
An array of objects where each object represents the NIS server and it's status for a given NIS domain. It is an advanced field. |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
Example request
"binding_details": [
"server": "string",
"status": {
"code": "string",
"message": "string"
"bound_servers": [
"string"
"domain": "domainA.example.com",
"servers": [
"10.10.10.10",
"example.com"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of NIS domain records. |
records |
array[nis_service] |
"num_records": 1,
"records": [
"server": "string",
"status": {
"code": "string",
"message": "string"
"bound_servers": [
"string"
"servers": [
"10.10.10.10",
"example.com"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966253 |
IPv6 is not enabled in the cluster |
2621488 |
Invalid SVM context |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
3276964 |
NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters |
3276933 |
A maximum of 10 NIS servers can be configured per SVM |
13434916 |
The SVM is in the process of being created. Wait a few minutes, and then try the command again. |
23724109 |
DNS resolution failed for one or more specified servers |
23724111 |
Empty NIS servers cannot be specified. |
23724112 |
DNS resolution failed due to an internal error. Contact technical support if this issue persists |
23724132 |
DNS resolution failed for all the specified servers |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 LIFs |
href |
string |
_links
binding_status
code |
string |
Code corresponding to the server's binding status. |
message |
string |
Detailed description of the server's binding status. |
binding_details
server |
string |
Hostname/IP address of the NIS server in the domain. |
status |
svm
name |
string |
uuid |
string |
nis_service
binding_details |
bound_servers |
array[string] |
domain |
string |
servers |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
