REST API reference
Create the FPolicy engine configuration for an SVM
Sets up an FPolicy engine configuration for a specified SVM, defining how the system interacts with external servers for file monitoring purposes. Use this endpoint when you need to enable file access auditing on data SVMs, with options for configuring primary and secondary servers for notification handling.
HTTP method and endpoint
POST /protocols/fpolicy/{svm.uuid}/engines
Introduced in
ONTAP 9.6
Usage notes
Creates an FPolicy engine configuration for a specified SVM. FPolicy engine creation is allowed only on data SVMs.
Required properties
  • svm.uuid - Existing SVM in which to create the FPolicy engine.
  • name - Name of external engine.
  • port - Port number of the FPolicy server application.
  • primary_servers - List of primary FPolicy servers to which the node will send notifications.
  • secondary_servers - It is recommended to configure secondary FPolicy server to which the node will send notifications when the primary server is down.
Default property values
  • type - synchronous
  • format - xml
  • fpolicy policy external-engine create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
buffer_size
buffer_size
Specifies the send and receive buffer size of the connected socket for the FPolicy server.
certificate
certificate
Provides details about certificate used to authenticate the FPolicy server.
format
string
The format for the notification messages sent to the FPolicy servers. The possible values are:
  • xml - Notifications sent to the FPolicy server will be formatted using the XML schema.
  • protobuf - Notifications sent to the FPolicy server will be formatted using Protobuf schema, which is a binary form.
keep_alive_interval
string
Specifies the ISO-8601 interval time for a storage appliance to send Keep Alive message to an FPolicy server. The allowed range is between 10 to 600 seconds.
max_server_requests
integer
Specifies the maximum number of outstanding requests for the FPolicy server. It is used to specify maximum outstanding requests that will be queued up for the FPolicy server. The value for this field must be between 1 and 10000. The default values are 500, 1000 or 2000 for Low-end(<64 GB memory), Mid-end(>=64 GB memory) and High-end(>=128 GB memory) Platforms respectively.
name
string
Specifies the name to assign to the external server configuration.
port
integer
primary_servers
array[string]
request_abort_timeout
string
Specifies the ISO-8601 timeout duration for a screen request to be aborted by a storage appliance. The allowed range is between 0 to 200 seconds.
request_cancel_timeout
string
Specifies the ISO-8601 timeout duration for a screen request to be processed by an FPolicy server. The allowed range is between 0 to 100 seconds.
resiliency
resiliency
If all primary and secondary servers are down, or if no response is received from the FPolicy servers, file access events are stored inside the storage controller under the specified resiliency-directory-path.
secondary_servers
array[string]
server_progress_timeout
string
Specifies the ISO-8601 timeout duration in which a throttled FPolicy server must complete at least one screen request. If no request is processed within the timeout, connection to the FPolicy server is terminated. The allowed range is between 0 to 100 seconds.
ssl_option
string
Specifies the SSL option for external communication with the FPolicy server. Possible values include the following:
  • no_auth When set to "no_auth", no authentication takes place.
  • server_auth When set to "server_auth", only the FPolicy server is authenticated by the SVM. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate.
  • mutual_auth When set to "mutual_auth", mutual authentication takes place between the SVM and the FPolicy server. This means authentication of the FPolicy server by the SVM along with authentication of the SVM by the FPolicy server. With this option, before creating the FPolicy external engine, the administrator must install the public certificate of the certificate authority (CA) that signed the FPolicy server certificate along with the public certificate and key file for authentication of the SVM.
status_request_interval
string
Specifies the ISO-8601 interval time for a storage appliance to query a status request from an FPolicy server. The allowed range is between 0 to 50 seconds.
svm
svm
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.6
    • x-nullable: true
Example request
  "certificate": {
    "ca": "TASample1",
    "name": "Sample1-FPolicy-Client",
    "serial_number": "8DDE112A114D1FBC"
  "format": "string",
  "keep_alive_interval": "PT2M",
  "max_server_requests": 500,
  "name": "fp_ex_eng",
  "port": 9876,
  "primary_servers": [
    "10.132.145.20",
    "10.140.101.109"
  "request_abort_timeout": "PT40S",
  "request_cancel_timeout": "PT20S",
  "resiliency": {
    "directory_path": "/dir1",
    "retention_duration": "PT3M"
  "secondary_servers": [
    "10.132.145.20",
    "10.132.145.21"
  "server_progress_timeout": "PT1M",
  "ssl_option": "string",
  "status_request_interval": "PT10S",
  "svm": {
    "uuid": "string"
  "type": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[fpolicy_engine]
  "num_records": 1,
  "records": [
      "certificate": {
        "ca": "TASample1",
      "format": "string",
      "port": 9876,
        "10.132.145.20",
        "10.140.101.109"
      "resiliency": {
        "10.132.145.20",
        "10.132.145.21"
      "svm": {
        "uuid": "string"
      "type": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
9764885
The primary secondary server has a redundant IP address
9764953
The name of the FPolicy engine is "native" which is reserved by the system
9765011
The resiliency feature is not supported with mandatory screening
9765012
The specified resiliency directory path does not exist
buffer_size
recv_buffer
integer
Specifies the receive buffer size of the connected socket for the FPolicy server. Default value is 256KB.
send_buffer
integer
Specifies the send buffer size of the connected socket for the FPolicy server. Default value 1MB.
certificate
ca
string
Specifies the certificate authority (CA) name of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
name
string
Specifies the certificate name as a fully qualified domain name (FQDN) or custom common name. The certificate is used if SSL authentication between the SVM and the FPolicy server is configured.
serial_number
string
Specifies the serial number of the certificate used for authentication if SSL authentication between the SVM and the FPolicy server is configured.
resiliency
directory_path
string
Specifies the directory path under the SVM namespace, where notifications are stored in the files whenever a network outage happens.
enabled
boolean
Specifies whether the resiliency feature is enabled or not. Default is false.
retention_duration
string
Specifies the ISO-8601 duration, for which the notifications are written to files inside the storage controller during a network outage. The value for this field must be between 0 and 600 seconds. Default is 180 seconds.
svm
uuid
string
SVM UUID
fpolicy_engine
Defines how ONTAP makes and manages connections to external FPolicy servers.
buffer_size
buffer_size
certificate
certificate
format
string
keep_alive_interval
string
max_server_requests
integer
name
string
port
integer
primary_servers
array[string]
string
string
resiliency
resiliency
secondary_servers
array[string]
string
ssl_option
string
string
svm
svm
type
string
    • Default value: 1
    • x-nullable: true
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
