REST API reference
Create the FPolicy engine configuration for an SVM
Configures the FPolicy engine for a specific SVM, which allows the SVM to manage external file screening and auditing processes. You use this configuration to set up communication with external FPolicy servers for monitoring and policy enforcement tasks.
HTTP method and endpoint
POST /protocols/fpolicy/{svm.uuid}/engines
Introduced in
ONTAP 9.6
Usage notes
Creates an FPolicy engine configuration for a specified SVM. FPolicy engine creation is allowed only on data SVMs.
Required properties
  • svm.uuid - Existing SVM in which to create the FPolicy engine.
  • name - Name of external engine.
  • port - Port number of the FPolicy server application.
  • primary_servers - List of primary FPolicy servers to which the node will send notifications.
  • secondary_servers - It is recommended to configure secondary FPolicy server to which the node will send notifications when the primary server is down.
Default property values
  • type - synchronous
  • fpolicy policy external-engine create
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
name
string
Specifies the name to assign to the external server configuration.
port
integer
primary_servers
array[string]
secondary_servers
array[string]
type
string
The notification mode determines what ONTAP does after sending notifications to FPolicy servers. The possible values are:
  • synchronous - After sending a notification, wait for a response from the FPolicy server.
  • asynchronous - After sending a notification, file request processing continues.
    • Default value: 1
    • enum: ["synchronous", "asynchronous"]
    • Introduced in: 9.6
Example request
  "name": "fp_ex_eng",
  "port": "9876",
  "primary_servers": [
    "10.132.145.20",
    "10.140.101.109"
  "secondary_servers": [
    "10.132.145.20",
    "10.132.145.21"
  "type": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[fpolicy_engine]
  "records": [
      "port": "9876",
        "10.132.145.20",
        "10.140.101.109"
        "10.132.145.20",
        "10.132.145.21"
      "type": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
9764885
The primary secondary server has a redundant IP address
9764953
The name of the FPolicy engine is "native" which is reserved by the system
fpolicy_engine
The engine defines how ONTAP makes and manages connections to external FPolicy servers.
name
string
port
integer
primary_servers
array[string]
secondary_servers
array[string]
type
string
    • Default value: 1
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
