REST API reference
Create a public key for a user account
POST /security/authentication/publickeys
Introduced In: 9.7
Creates a public key along with an optional certificate for a user account.
Required properties
  • owner.uuid - UUID of the account owner.
  • name - User account name.
  • index - Index number for the public key (where there are multiple keys for the same account).
  • public_key - The publickey details for the creation of the user account.
Optional properties
  • comment - Comment text for the public key.
  • certificate - The certificate in PEM format.
  • security login publickey create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
account
account_reference
certificate
string
Optional certificate for the public key.
certificate_details
string
The details present in the certificate (READONLY).
certificate_expired
string
The expiration details of the certificate (READONLY).
certificate_revoked
string
The revocation details of the certificate (READONLY).
comment
string
Optional comment for the public key.
index
integer
obfuscated_fingerprint
string
The obfuscated fingerprint for the public key (READONLY).
owner
owner
Owner name and UUID that uniquely identifies the public key.
public_key
string
The public key
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
The SHA fingerprint for the public key (READONLY).
Example request
  "account": {
    "name": "joe.smith"
  "certificate": "string",
  "certificate_details": "string",
  "certificate_expired": "string",
  "certificate_revoked": "string",
  "comment": "string",
  "obfuscated_fingerprint": "string",
  "owner": {
    "name": "svm1",
  "public_key": "string",
  "scope": "string",
  "sha_fingerprint": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5832705
Public key already exists for the given user and application.
5832707
Failed to generate fingerprint for the public key.
5832722
The public key cannot be associated with this user on the SVM because a login method using the given application and authentication method does not exist for this user.
string
account_reference
name
string
User account
owner
name
string
uuid
string
publickey
The public key for the user account (to access SSH).
account
account_reference
certificate
string
certificate_details
string
certificate_expired
string
certificate_revoked
string
comment
string
index
integer
string
owner
owner
public_key
string
The public key
scope
string
sha_fingerprint
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
