Create a public key for a user account
Creates a public key for a user account, allowing secure authentication and access management. Use this endpoint to add a public key when configuring or updating user accounts with secure credentials.
HTTP method and endpoint
POST /security/authentication/publickeys
Introduced in
ONTAP 9.7
Required properties
owner.uuid- UUID of the account owner. -
name- User account name. -
index- Index number for the public key (where there are multiple keys for the same account). -
public_key- The publickey details for the creation of the user account.
Related ONTAP commands
security login publickey create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
account |
comment |
string |
Optional comment for the public key. |
index |
integer |
Index number for the public key (where there are multiple keys for the same account). |
obfuscated_fingerprint |
string |
The obfuscated fingerprint for the public key (READONLY). |
owner |
Owner name and UUID that uniquely identifies the public key. |
public_key |
string |
The public key |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
The SHA fingerprint for the public key (READONLY). |
Example request
"account": {
"name": "joe.smith"
"comment": "string",
"obfuscated_fingerprint": "string",
"owner": {
"name": "svm1",
"public_key": "string",
"scope": "string",
"sha_fingerprint": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default, Error
href |
string |
_links
account_reference
_links |
name |
string |
User account |
owner
name |
string |
The name of the SVM. |
uuid |
string |
publickey
The public key for the user account (to access SSH).
account |
comment |
string |
index |
integer |
string |
owner |
public_key |
string |
The public key |
scope |
string |
sha_fingerprint |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
