Create a public key for a user account
POST /security/authentication/publickeys
Creates a public key for a user account.
Learn more
return_records  |
boolean  |
query  |
False  |
The default is false. If set to true, the records are returned.  |
Request Body
| Name | Type | Description |
_links  |
account  |
comment  |
string  |
Optional comment for the public key.  |
index  |
integer  |
Index number for the public key (where there are multiple keys for the same account).  |
obfuscated_fingerprint  |
string  |
The obfuscated fingerprint for the public key (READONLY).  |
owner  |
Owner name and UUID that uniquely identifies the public key.  |
public_key  |
string  |
The public key  |
scope  |
string  |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.  |
sha_fingerprint  |
string  |
The SHA fingerprint for the public key (READONLY).  |
Example request
      "href": "/api/resourcelink"
  "account": {
    "name": "joe.smith"
  "comment": "string",
  "obfuscated_fingerprint": "string",
  "owner": {
    "name": "svm1",
  "public_key": "string",
  "scope": "string",
  "sha_fingerprint": "string"
Status: 201, Created
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
account_reference
_links  |
name  |
string  |
User account  |
owner
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
publickey
The public key for the user account (to access SSH).
_links  |
account  |
comment  |
string  |
index  |
integer  |
string  |
owner  |
public_key  |
string  |
The public key  |
scope  |
string  |
sha_fingerprint  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
