REST API reference
Create an AKV configuration for all clusters and SVMs
Configures Azure Key Vault (AKV) settings for all clusters and SVMs, specifying the application and directory IDs, as well as authentication details for accessing AKV. This setup is essential for managing encryption keys used by ONTAP.
HTTP method and endpoint
POST /security/azure-key-vaults
Introduced in
ONTAP 9.8
Usage notes
Configures the AKV configuration for all clusters and SVMs.
Required properties:
  • svm.uuid or svm.name - Existing SVM in which to create a AKV.
  • client_id - Application (client) ID of the deployed Azure application with appropriate access to an AKV.
  • tenant_id - Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.
  • client_secret or client_certificate - Secret or PKCS12 Certificate used by the application to prove its identity to AKV.
  • key_id- Key Identifier of AKV encryption key.
  • name - Name of the deployed AKV used by ONTAP for storing keys.
Optional properties:
  • port - Authorization server and vault port number.
  • oauth_host - Open authorization server host name.
  • vault_host - AKV host subdomain.
  • proxy_type - Type of proxy (http, https etc.) if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • configuration.name - The configuration name to use when also setting the create_inactive flag.
Optional parameters:
  • create_inactive - Create an AKV configuration without enabling it. This flag is set to "false" by default.
  • security key-manager external azure enable
  • security key-manager external azure create-config
  • security key-manager external azure update-config
create_inactive
boolean
query
False
Indicates whether to create an active or inactive configuration.
  • Introduced in: 9.15
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
authentication_method
string
Authentication method for the AKV instance.
azure_reachability
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
client_certificate
string
client_id
string
Application client ID of the deployed Azure application with appropriate access to an AKV.
client_secret
string
Secret used by the application to prove its identity to AKV.
configuration
configuration
Security keystore object reference.
ekmip_reachability
array[ekmip_reachability]
enabled
boolean
Indicates whether the configuration is enabled.
key_id
string
Key Identifier of AKV key encryption key.
name
string
Name of the deployed AKV that will be used by ONTAP for storing keys.
oauth_host
string
port
integer
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
state
state
Indicates whether or not the AKV wrapped internal key is available cluster wide. This is an advanced property; there is an added computationl cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
svm
svm
tenant_id
string
uuid
string
A unique identifier for the Azure Key Vault (AKV).
vault_host
string
AKV host subdomain.
Example request
  "authentication_method": "client_secret",
  "azure_reachability": {
    "code": "346758",
    "message": "AKV service is not reachable from all nodes - reason."
  "client_certificate": "<CERTIFICATE-CONTENT>",
  "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
  "client_secret": "abcdef",
  "configuration": {
    "name": "default",
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "key_id": "https://keyvault1.vault.azure.net/keys/key1/12345678901234567890123456789012",
  "name": "https://kmip-akv-keyvault.vault.azure.net/",
  "oauth_host": "login.microsoftonline.com",
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_password": "proxypassword",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "scope": "string",
  "state": {
    "code": "346758",
    "message": "Top-level internal key protection key (KEK) is unavailable on the following nodes with the associated reasons: Node: node1. Reason: No volumes created yet for the SVM. Wrapped KEK status will be available after creating encrypted volumes."
  "svm": {
    "name": "svm1",
  "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "vault_host": "vault.azure.net",
  "verify_host": "",
  "verify_ip": ""
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
3735553
Failed to create self-signed certificate.
3735664
The specified key size is not supported in FIPS mode.
3735665
The specified hash function is not supported in FIPS mode.
3735700
The specified key size is not supported.
52559972
The certificates start date is later than the current date.
65537500
A key manager has already been configured for this SVM.
65537504
Internal error. Failed to store configuration in internal database.
65537505
One or more volume encryption keys of the given SVM are stored on a key manager configured for the admin SVM.
65537506
AKV is not supported in MetroCluster configurations.
65537512
AKV cannot be configured for the given SVM as not all nodes in the cluster can enable the Azure Key Vault feature.
65537514
Failed to check if the Azure Key Vault feature is enabled.
65537518
Failed to find an interface with Cluster role.
65537523
Invalid key ID format. Example key ID format":" "https://mykeyvault.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74".
65537526
Failed to enable Azure Key Vault feature.
65537567
No authentication method provided.
65537573
Invalid client certificate.
65537589
The specified configuration.name already exists on the given SVM.
65537592
The configuration.name field requires an ECV of 9.14.0 or greater.
65537593
The create_inactive flag requires an effective cluster version of 9.14.0 or greater.
65537594
The configuration.name field is required when the create_inactive flag is set to true.
65537595
The configuration.name field can only be specified when the create_inactive flag is set to true.
65538902
The configuration.name is reserved for use by the system.
65538903
The configuration.name field cannot be an empty string.
65539703
The key manager cannot be configured because the SVM has NAE volumes.
string
azure_reachability
code
string
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster.
message
string
Error message set when reachability is false.
reachable
boolean
Set to true when the AKV service is reachable from all nodes of the cluster.
configuration
name
string
Name of the configuration.
uuid
string
Keystore UUID.
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
available
boolean
Set to true when an AKV wrapped internal key is present on all nodes of the cluster.
code
string
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster.
message
string
Error message set when top-level internal key protection key (KEK) availability on cluster is false.
svm
name
string
uuid
string
azure_key_vault
_links
_links
string
azure_reachability
azure_reachability
client_certificate
string
client_id
string
client_secret
string
configuration
configuration
ekmip_reachability
enabled
boolean
key_id
string
name
string
oauth_host
string
port
integer
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Type of proxy.
proxy_username
string
Proxy username.
scope
string
state
state
svm
svm
tenant_id
string
uuid
string
vault_host
string
AKV host subdomain.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
