Create an AKV configuration for all clusters and SVMs
Configures AKV settings for all clusters and SVMs, establishing the necessary parameters for secure key management in Azure environments. This is particularly useful for setting up encryption key access across your Azure NetApp Files Cloud Volume Services.
HTTP method and endpoint
POST /security/azure-key-vaults
Introduced in
ONTAP 9.8
Usage notes
Configures the AKV configuration for all clusters and SVMs. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a AKV. -
client_id- Application (client) ID of the deployed Azure application with appropriate access to an AKV. -
tenant_id- Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. -
client_secret- Password used by the application to prove its identity to AKV. -
key_id- Key Identifier of AKV encryption key. -
name- Name of the deployed AKV used by the Azure NetApp Files Cloud Volume Services for storing keys.
Optional properties
proxy_type- Type of proxy (http, https etc.) if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used.
Related ONTAP commands
security key-manager external azure enable -
security key-manager external azure update-config
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
client_id |
string |
Application client ID of the deployed Azure application with appropriate access to an AKV. |
client_secret |
string |
Password used by the application to prove its identity to AKV. |
ekmip_reachability |
array[ekmip_reachability] |
key_id |
string |
Key Identifier of AKV key encryption key. |
name |
string |
Name of the deployed AKV that is used by the Azure NetApp Files Cloud Volume Services for storing keys. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
tenant_id |
string |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV. |
uuid |
string |
A unique identifier for the Azure Key Vault (AKV). |
Example request
"client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
"client_secret": "abcdef",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"key_id": "https://keyvault1.vault.azure.net/keys/key1",
"name": "https://kmip-akv-keyvault.vault.azure.net/",
"proxy_host": "proxy.eng.com",
"proxy_password": "proxypassword",
"proxy_port": "1234",
"proxy_type": "http",
"proxy_username": "proxyuser",
"svm": {
"name": "svm1",
"tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[azure_key_vault] |
"records": [
"code": "346758",
"node": {
"name": "node1",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735553 |
Failed to create self-signed certificate. |
3735664 |
The specified key size is not supported in FIPS mode. |
3735665 |
The specified hash function is not supported in FIPS mode. |
3735700 |
The specified key size is not supported. |
52559972 |
The certificates start date is later than the current date. |
65537500 |
A key manager has already been configured for this SVM. |
65537504 |
Internal error. Failed to store configuration in internal database. |
65537505 |
One or more volume encryption keys of the given SVM are stored on a key manager configured for the admin SVM. |
65537506 |
AKV is not supported in MetroCluster configurations. |
65537512 |
AKV cannot be configured for the given SVM as not all nodes in the cluster can enable the Azure Key Vault feature. |
65537514 |
Failed to check if the Azure Key Vault feature is enabled. |
65537518 |
Failed to find an interface with Cluster role. |
65537523 |
Invalid key ID format. Example key ID format":" "https://mykeyvault.vault.azure.net/keys/key1". |
65537526 |
Failed to enable Azure Key Vault feature. |
href |
string |
_links
azure_reachability
Indicates whether or not the AKV service is reachable from all the nodes in the cluster.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV service is reachable from all nodes in the cluster. |
message |
string |
Error message set when reachability is false. |
reachable |
boolean |
Set to true when the AKV service is reachable from all nodes of the cluster. |
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
integer |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
Indicates whether or not the AKV wrapped internal key is available cluster wide.
available |
boolean |
Set to true when an AKV wrapped internal key is present on all nodes of the cluster. |
code |
integer |
Code corresponding to the status message. Returns a 0 if AKV wrapped key is available on all nodes in the cluster. |
message |
string |
Error message set when top-level internal key protection key (KEK) availability on cluster is false. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
azure_key_vault
client_id |
string |
client_secret |
string |
key_id |
string |
name |
string |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Type of proxy. |
proxy_username |
string |
Proxy username. |
svm |
tenant_id |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
