Create a certificate signing request
Generates a certificate signing request (CSR) and a private key pair to apply for a digital identity certificate. Use this API when you need to securely send a CSR to a certificate authority for certificate issuance.
HTTP method and endpoint
POST /security/certificate-signing-request
Introduced in
ONTAP 9.8
Usage notes
This API generates a Certificate Signing Request(CSR) and a private key pair. A CSR is a message sent securely to a certificate authority (CA) via any electronic media to apply for a digital identity certificate. This is a general utility API for users to generate a CSR.
Required properties
subject_name- Subject details of the certificate, including but not limited to the common name. Can be omitted if subject_alternatives is specified. -
subject_alternatives- Subject Alternate Name (SAN) extensions. Only required if a common name is not specified using subject_name.
Recommended optional properties
security_strength- Key size of the certificate, in bits. Specifying a stronger security strength in bits is recommended when creating a certificate. A value of at least 128 is necessary when using EC algorithm if the certificate is to be used in the context of TLSv1.3. -
hash_function- Hashing function. -
algorithm- Asymmetric algorithm. Algorithm used to generate a public/private key pair when creating a certificate.
Default property values
If not specified in POST, the following default property values are assigned:
security_strength- 112 -
hash_function- sha256 -
algorithm- rsa
Related ONTAP commands
security certificate generate-csr
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
algorithm |
string |
Asymmetric Encryption Algorithm. |
csr |
string |
A Certificate Signing Request (CSR) provided to a CA for obtaining a CA-signed certificate. |
extended_key_usages |
array[string] |
A list of extended key usage extensions. |
generated_private_key |
string |
Private key generated for the CSR. |
hash_function |
string |
Hashing function. |
key_usages |
array[string] |
A list of key usage extensions. |
security_strength |
integer |
Security strength of the certificate in bits. |
subject_alternatives |
subject_name |
string |
Subject name details of the certificate. The format is a list of comma separated key=value pairs. |
Example request
"algorithm": "string",
"csr": "string",
"extended_key_usages": [
"string"
"generated_private_key": "string",
"hash_function": "string",
"key_usages": [
"string"
"security_strength": 112,
"subject_alternatives": {
"dns": [
"*.example.com"
"email": [
"abc@example.com"
"ip": [
"10.225.34.10"
"uri": [
"http://example.com"
"subject_name": "C=US,O=NTAP,CN=test.domain.com"
Status: 200, Ok
algorithm |
string |
csr |
string |
array[string] |
string |
hash_function |
string |
Hashing function. |
key_usages |
array[string] |
security_strength |
integer |
subject_name |
string |
"csr": "string",
"string"
"key_usages": [
"string"
"dns": [
"*.example.com"
"email": [
"abc@example.com"
"ip": [
"10.225.34.10"
"uri": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735554 |
Certificate signing request failed. |
3735664 |
Key size is not supported in FIPS mode. |
3735665 |
Hash function is not supported in FIPS mode. |
3735700 |
Key size is not supported. |
3735713 |
Security strength bits length is not supported. |
3735714 |
Security strength bits length is not supported in FIPS mode. |
3735715 |
Certificate creation requires a common name or SAN extensions. |
3735741 |
Key size is not applicable with the EC encryption algorithm. |
3735750 |
Cannot supply "critical" as the only value in a list of extension values. |
52560173 |
Hash function is not supported for digital signatures. |
52560423 |
Failed to read the relative distinguished names. |
href |
string |
_links
dns |
array[string] |
A list of DNS names for Subject Alternate name extension. |
array[string] |
A list of email addresses for Subject Alternate name extension |
ip |
array[string] |
A list of IP addresses for Subject Alternate name extension. |
uri |
array[string] |
A list of URIs for Subject Alternate name extension. |
certificate_signing_request
algorithm |
string |
csr |
string |
array[string] |
string |
hash_function |
string |
Hashing function. |
key_usages |
array[string] |
security_strength |
integer |
subject_name |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
