REST API reference
Create a certificate signing request
Generates a certificate signing request (CSR) and a private key pair to apply for a digital identity certificate. Use this API when you need to securely send a CSR to a certificate authority for certificate issuance.
HTTP method and endpoint
POST /security/certificate-signing-request
Introduced in
ONTAP 9.8
Usage notes
This API generates a Certificate Signing Request(CSR) and a private key pair. A CSR is a message sent securely to a certificate authority (CA) via any electronic media to apply for a digital identity certificate. This is a general utility API for users to generate a CSR.
Required properties
  • subject_name - Subject details of the certificate, including but not limited to the common name. Can be omitted if subject_alternatives is specified.
  • subject_alternatives - Subject Alternate Name (SAN) extensions. Only required if a common name is not specified using subject_name.
  • security_strength - Key size of the certificate, in bits. Specifying a stronger security strength in bits is recommended when creating a certificate. A value of at least 128 is necessary when using EC algorithm if the certificate is to be used in the context of TLSv1.3.
  • hash_function - Hashing function.
  • algorithm - Asymmetric algorithm. Algorithm used to generate a public/private key pair when creating a certificate.
Default property values
If not specified in POST, the following default property values are assigned:
  • security_strength - 112
  • hash_function - sha256
  • algorithm - rsa
  • security certificate generate-csr
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
algorithm
string
Asymmetric Encryption Algorithm.
csr
string
A Certificate Signing Request (CSR) provided to a CA for obtaining a CA-signed certificate.
extended_key_usages
array[string]
A list of extended key usage extensions.
generated_private_key
string
Private key generated for the CSR.
hash_function
string
Hashing function.
key_usages
array[string]
A list of key usage extensions.
security_strength
integer
Security strength of the certificate in bits.
subject_name
string
Subject name details of the certificate. The format is a list of comma separated key=value pairs.
Example request
  "algorithm": "string",
  "csr": "string",
  "extended_key_usages": [
    "string"
  "generated_private_key": "string",
  "hash_function": "string",
  "key_usages": [
    "string"
  "security_strength": 112,
  "subject_alternatives": {
    "dns": [
      "*.example.com"
    "email": [
      "abc@example.com"
    "ip": [
      "10.225.34.10"
    "uri": [
      "http://example.com"
  "subject_name": "C=US,O=NTAP,CN=test.domain.com"
Status: 200, Ok
algorithm
string
csr
string
extended_key_usages
array[string]
string
hash_function
string
Hashing function.
key_usages
array[string]
security_strength
integer
subject_name
string
  "csr": "string",
    "string"
  "key_usages": [
    "string"
    "dns": [
      "*.example.com"
    "email": [
      "abc@example.com"
    "ip": [
      "10.225.34.10"
    "uri": [
Status: Default
ONTAP Error Response Codes
Error Code Description
3735554
Certificate signing request failed.
3735664
Key size is not supported in FIPS mode.
3735665
Hash function is not supported in FIPS mode.
3735700
Key size is not supported.
3735713
Security strength bits length is not supported.
3735714
Security strength bits length is not supported in FIPS mode.
3735715
Certificate creation requires a common name or SAN extensions.
3735741
Key size is not applicable with the EC encryption algorithm.
3735750
Cannot supply "critical" as the only value in a list of extension values.
52560173
Hash function is not supported for digital signatures.
52560423
Failed to read the relative distinguished names.
string
dns
array[string]
A list of DNS names for Subject Alternate name extension.
email
array[string]
A list of email addresses for Subject Alternate name extension
ip
array[string]
A list of IP addresses for Subject Alternate name extension.
uri
array[string]
A list of URIs for Subject Alternate name extension.
certificate_signing_request
algorithm
string
csr
string
extended_key_usages
array[string]
string
hash_function
string
Hashing function.
key_usages
array[string]
security_strength
integer
subject_name
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
