REST API reference
Create the TOTP profile for a user account
POST /security/login/totps
Introduced In: 9.13
Creates a TOTP profile for a user account.
Required properties
  • owner.uuid - Account owner UUID.
  • account.name - Account user name.
  • security login totp create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
account
account_reference
comment
string
Optional comment for the TOTP profile.
owner
owner
Owner name and UUID that uniquely identifies the TOTP profile.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
sha_fingerprint
string
SHA fingerprint for the TOTP secret key.
Example request
  "account": {
    "name": "joe.smith"
  "comment": "string",
  "enabled": "",
  "owner": {
    "name": "svm1",
  "scope": "string",
  "sha_fingerprint": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[totp_post]
  "num_records": 1,
  "records": [
      "account": {
        "name": "joe.smith"
      "emergency_codes": "17503785",
      "enabled": 1,
      "install_url": "string",
      "owner": {
        "name": "svm1",
      "scope": "string",
      "secret_key": "string",
      "sha_fingerprint": "string",
      "verification_code": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
144834561
TOTP is not configured for the user.
string
account_reference
name
string
User account
owner
name
string
uuid
string
totp
TOTP profile for the user account used to access SSH.
account
account_reference
comment
string
owner
owner
scope
string
sha_fingerprint
string
totp_post
Response object of the TOTP profile creation.
account
account_reference
comment
string
emergency_codes
array[string]
TOTP profile emergency codes for a user. These codes are for emergency use when a user cannot access 2FA codes through other means.
install_url
string
TOTP profile installation URL for a user.
owner
owner
scope
string
secret_key
string
TOTP profile secret key for a user.
sha_fingerprint
string
verification_code
string
TOTP profile verification code for a user.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
