Create the TOTP profile for a user account
Creates a TOTP profile for a user account to enable time-based one-time password authentication for enhanced security.
HTTP method and endpoint
POST /security/login/totps
Introduced in
ONTAP 9.13
Required properties
owner.uuid- Account owner UUID. -
account.name- Account user name.
Related ONTAP commands
security login totp create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
account |
comment |
string |
Optional comment for the TOTP profile. |
owner |
Owner name and UUID that uniquely identifies the TOTP profile. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
sha_fingerprint |
string |
SHA fingerprint for the TOTP secret key. |
Example request
"account": {
"name": "joe.smith"
"comment": "string",
"enabled": "",
"owner": {
"name": "svm1",
"scope": "string",
"sha_fingerprint": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[totp_post] |
"num_records": 1,
"records": [
"account": {
"name": "joe.smith"
"emergency_codes": "17503785",
"enabled": 1,
"install_url": "string",
"owner": {
"name": "svm1",
"scope": "string",
"secret_key": "string",
"sha_fingerprint": "string",
"verification_code": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
144834561 |
TOTP is not configured for the user. |
href |
string |
_links
account_reference
name |
string |
User account |
owner
name |
string |
uuid |
string |
totp
TOTP profile for the user account used to access SSH.
account |
comment |
string |
owner |
scope |
string |
sha_fingerprint |
string |
totp_post
Response object of the TOTP profile creation.
account |
comment |
string |
emergency_codes |
array[string] |
TOTP profile emergency codes for a user. These codes are for emergency use when a user cannot access 2FA codes through other means. |
install_url |
string |
TOTP profile installation URL for a user. |
owner |
scope |
string |
secret_key |
string |
TOTP profile secret key for a user. |
sha_fingerprint |
string |
verification_code |
string |
TOTP profile verification code for a user. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
