REST API reference
Attach an object store to an aggregate or add a second object store as a mirror
Attaches an object store to an aggregate or add a second object store as a mirror, depending on your configuration needs. Use this endpoint to manage your storage resources effectively by selecting the appropriate cloud target and settings.
HTTP method and endpoint
POST /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced in
ONTAP 9.6
Usage notes
Attaches an object store to an aggregate, or adds a second object store as a mirror.
Required properties
  • target.uuid or target.name - UUID or name of the cloud target.
  • primary - true if the object store is primary or false if it is a mirror.
  • allow_flexgroups - Allow attaching object store to an aggregate containing FlexGroup constituents.
  • check_only - Validate only and do not add the cloud store.
Default property values
  • primary - true
  • allow_flexgroups - false
  • check_only - false
  • storage aggregate object-store attach
  • storage aggregate object-store mirror
aggregate.uuid
string
path
True
Aggregate UUID
allow_flexgroups
boolean
query
False
This optional parameter allows attaching object store to an aggregate containing FlexGroup constituents. The default value is false. Mixing FabricPools and non-FabricPools within a FlexGroup is not recommended. All aggregates hosting constituents of a FlexGroup should be attached to the object store.
check_only
boolean
query
False
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregate
aggregate
Aggregate
availability
string
Availability of the object store.
availability_at_partner
string
Availability of the object store at the HA partner.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
resync-progress
integer
Resync progress of the mirror object store in percentage.
target
target
Cloud target
unavailable_reason
unavailable_reason
unreclaimed_space_threshold
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
Example request
  "aggregate": {
    "name": "aggr1"
  "availability": "string",
  "availability_at_partner": "string",
  "resync-progress": 0,
  "target": {
    "name": "target1",
  "unavailable_reason": {
    "message": "string"
  "unreclaimed_space_threshold": 20,
  "used": 0
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
787143
Object store is already attached to FabricPool.
787144
Aggregate is not a FabricPool.
787205
The operation failed because the previous unmirror operation on the aggregate is still in progress. Check that the previous unmirror operation is complete and try the command again.
787218
The specified object store does not exist.
7209876
Aggregate is already a FabricPool Aggregate.
string
aggregate
Aggregate
name
string
target
Cloud target
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
cloud_store
aggregate
aggregate
Aggregate
availability
string
string
mirror_degraded
boolean
primary
boolean
resync-progress
integer
target
target
Cloud target
unavailable_reason
unavailable_reason
integer
used
integer
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
