Attach an object store to an aggregate or add a second object store as a mirror
Attaches an object store to an aggregate or add a second object store as a mirror, depending on your configuration needs. Use this endpoint to manage your storage resources effectively by selecting the appropriate cloud target and settings.
HTTP method and endpoint
POST /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced in
ONTAP 9.6
Usage notes
Attaches an object store to an aggregate, or adds a second object store as a mirror.
Required properties
target.uuidortarget.name- UUID or name of the cloud target.
Recommended optional properties
primary- true if the object store is primary or false if it is a mirror. -
allow_flexgroups- Allow attaching object store to an aggregate containing FlexGroup constituents. -
check_only- Validate only and do not add the cloud store.
Default property values
primary- true -
allow_flexgroups- false -
check_only- false
Related ONTAP commands
storage aggregate object-store attach -
storage aggregate object-store mirror
aggregate.uuid |
string |
path |
True |
Aggregate UUID |
allow_flexgroups |
boolean |
query |
False |
This optional parameter allows attaching object store to an aggregate containing FlexGroup constituents. The default value is false. Mixing FabricPools and non-FabricPools within a FlexGroup is not recommended. All aggregates hosting constituents of a FlexGroup should be attached to the object store. |
check_only |
boolean |
query |
False |
Validate only and do not add the cloud store. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
aggregate |
Aggregate |
availability |
string |
Availability of the object store. |
mirror_degraded |
boolean |
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool. |
primary |
boolean |
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool. |
resync-progress |
integer |
Resync progress of the mirror object store in percentage. |
target |
Cloud target |
unavailable_reason |
unreclaimed_space_threshold |
integer |
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST. |
used |
integer |
The amount of object space used. Calculated every 5 minutes and cached. |
Example request
"aggregate": {
"name": "aggr1"
"availability": "string",
"resync-progress": 0,
"target": {
"name": "target1",
"unavailable_reason": {
"message": "string"
"unreclaimed_space_threshold": 20,
"used": 0
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787143 |
Object store is already attached to FabricPool. |
787144 |
Aggregate is not a FabricPool. |
787205 |
The operation failed because the previous unmirror operation on the aggregate is still in progress. Check that the previous unmirror operation is complete and try the command again. |
787218 |
The specified object store does not exist. |
7209876 |
Aggregate is already a FabricPool Aggregate. |
href |
string |
_links
aggregate
Aggregate
name |
string |
target
Cloud target
name |
string |
uuid |
string |
message |
string |
Indicates why the object store is unavailable. |
cloud_store
aggregate |
Aggregate |
availability |
string |
mirror_degraded |
boolean |
primary |
boolean |
resync-progress |
integer |
target |
Cloud target |
integer |
used |
integer |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
