REST API reference
Attach an object store to an aggregate or add a second object store as a mirror
POST /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced In: 9.6
Attaches an object store to an aggregate, or adds a second object store as a mirror.
Required properties
  • target.uuid or target.name - UUID or name of the cloud target.
  • primary - true if the object store is primary or false if it is a mirror.
  • allow_flexgroups - Allow attaching object store to an aggregate containing FlexGroup constituents.
  • check_only - Validate only and do not add the cloud store.
Default property values
  • primary - true
  • allow_flexgroups - false
  • check_only - false
  • storage aggregate object-store attach
  • storage aggregate object-store mirror
aggregate.uuid
string
path
True
Aggregate UUID
allow_flexgroups
boolean
query
False
This optional parameter allows attaching object store to an aggregate containing FlexGroup constituents. The default value is false. Mixing FabricPools and non-FabricPools within a FlexGroup is not recommended. All aggregates hosting constituents of a FlexGroup should be attached to the object store.
check_only
boolean
query
False
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
availability
string
Availability of the object store.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
target
target
Cloud target
unavailable_reason
unavailable_reason
unreclaimed_space_threshold
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
Example request
  "availability": "string",
  "target": {
    "name": "target1",
  "unavailable_reason": {
    "message": "string"
  "unreclaimed_space_threshold": "20",
  "used": 0
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
target
Cloud target
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
cloud_store
availability
string
mirror_degraded
boolean
primary
boolean
target
target
Cloud target
unavailable_reason
unavailable_reason
integer
used
integer
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
