Restore the source directory from the volume Snapshot copy on the destination directory
Restores a source directory from a volume Snapshot copy to a specified destination directory, enabling data recovery or rollback to a previous state.
HTTP method and endpoint
POST /storage/directory-restore
Introduced in
ONTAP 9.15
Usage notes
Restores the source directory from the volume Snapshot copy on the destination directory.
Required Properties
vserver -
volume.name -
snapshot.name -
source_path -
restore_path
Related ONTAP commands
volume snapshot directory-restore start
# The API:
/api/storage/directory-restore
# The call:
curl -X POST "https://<mgmt_ip>/api/storage/directory-restore" -H "accept: application/hal+json" -d '{"svm":"vs1", "volume": "vol1", "snapshot": "sp1", "path": "/aaaa", "restore_path": "/bbbb"}'
# The response:
"job": {
"uuid": "23b5ff3a-4743-11ee-a08d-005056bb9d00",
"href": "/api/cluster/jobs/23b5ff3a-4743-11ee-a08d-005056bb9d00"
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
path |
string |
Source from where the directory is restored. |
restore_path |
string |
Destination directory where the new directory tree is created. |
snapshot |
string |
Name of the volume Snapshot copy from which the directory is restored. |
volume |
string |
Name of the volume from which the Snapshot copy is used for directory restore. |
vserver |
string |
Name of the SVM. |
Example request
"path": "src_file1, dir1/src_file2, ./.snapshot/snap1/src_file3",
"restore_path": "dest_file1, dir1/dest_file2",
"snapshot": "string",
"volume": "string",
"vserver": "string"
Status: 202, Accepted
path |
string |
restore_path |
string |
snapshot |
string |
volume |
string |
vserver |
string |
Name of the SVM. |
"volume": "string",
"vserver": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
6488112 |
Directory restore can only be started on a directory. |
6488113 |
Directory restore requires an effective cluster version of 9.15.1 or later. |
6488114 |
Directory restore is not supported on FlexGroup constituent volumes. |
6488115 |
Internal error. Failed to get node information for the volume with DSID "volume.dsid". |
6488116 |
Directory restore is not supported on root directory. Use the "volume snapshot restore" command instead. |
directory_restore
Restores a directory from a volume Snapshot copy.
path |
string |
restore_path |
string |
snapshot |
string |
volume |
string |
vserver |
string |
Name of the SVM. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
