REST API reference
Restore the source directory from the volume snapshot on the destination directory
Restores a source directory from a volume snapshot to a specified destination directory. This operation is useful when you need to recover data from a specific point in time.
HTTP method and endpoint
POST /storage/directory-restore
Introduced in
ONTAP 9.15
Usage notes
Restores the source directory from the volume snapshot on the destination directory.
Required Properties
  • vserver
  • volume.name
  • snapshot.name
  • source_path
  • restore_path
  • volume snapshot directory-restore start
# The API:
/api/storage/directory-restore
# The call:
curl -X POST "https://<mgmt_ip>/api/storage/directory-restore" -H "accept: application/hal+json" -d '{"svm":"vs1", "volume": "vol1", "snapshot": "sp1", "path": "/aaaa", "restore_path": "/bbbb"}'
# The response:
"job": {
  "uuid": "23b5ff3a-4743-11ee-a08d-005056bb9d00",
      "href": "/api/cluster/jobs/23b5ff3a-4743-11ee-a08d-005056bb9d00"
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
path
string
Source from where the directory is restored.
restore_path
string
Destination directory where the new directory tree is created.
snapshot
string
Name of the volume snapshot from which the directory is restored.
volume
string
Name of the volume from which the snapshot is used for directory restore.
vserver
string
Name of the SVM.
Example request
  "path": "src_file1 or dir1/src_file2 or ./.snapshot/snap1/src_file3",
  "restore_path": "dest_file1 or dir1/dest_file2",
  "snapshot": "string",
  "volume": "string",
  "vserver": "string"
Status: 202, Accepted
path
string
restore_path
string
snapshot
string
volume
string
vserver
string
Name of the SVM.
  "volume": "string",
  "vserver": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
6488112
Directory restore can only be started on a directory.
6488113
Directory restore requires an effective cluster version of 9.15.1 or later.
6488114
Directory restore is not supported on FlexGroup constituent volumes.
6488115
Internal error. Failed to get node information for the volume with DSID "volume.dsid".
6488116
Directory restore is not supported on root directory. Use the "volume snapshot restore" command instead.
directory_restore
Restores a directory from a volume snapshot.
path
string
restore_path
string
snapshot
string
volume
string
vserver
string
Name of the SVM.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
