Create an event filter
POST /support/ems/filters
Introduced In: 9.6
Creates an event filter.
Required properties
name- String that uniquely identifies the filter.
Recommended optional properties
rules- List of criteria which is used to match a filter with an event.
Related ONTAP commands
event filter create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
access_control_role |
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
system_defined |
boolean |
Flag indicating system-defined filters. |
Example request
"access_control_role": {
"name": "admin"
"name": "wafl-critical-events",
"rules": [
"index": 1,
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error",
"snmp_trap_types": "standard,built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
"system_defined": 1
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"name": "admin"
"rules": [
"index": 1,
"type": "include"
"system_defined": 1
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The filter name provided is empty |
983089 |
The filter name provided cannot contain spaces |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983094 |
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen) |
983095 |
The rule index provided is invalid for the filter provided |
983101 |
No event is matched by the rule provided |
983113 |
Default filters cannot be modified or removed |
983114 |
The maximum number of filters is reached |
983115 |
The maximum number of filter rules is reached |
983126 |
A rule requires at least one name_pattern, severities, snmp_trap_types, or parameter pattern to be defined |
983127 |
A property cannot contain a combination of the wildcard character and other values |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severities provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types properties do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
983195 |
Empty field in parameter_criteria. Both name and value patterns must be specified |
983196 |
name_pattern and value_pattern fields in parameter_criteria are empty |
983211 |
Parameter criteria based filtering is not supported in this version of ONTAP |
983216 |
The provided parameter criteria does not match that of the message name |
href |
string |
_links
access_control_role
name |
string |
Role name |
message_criteria
Matching message definitions for the filter. A property must be specified.
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
rules
Rule for an event filter
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
ems_filter
name |
string |
Filter name |
rules |
array[rules] |
system_defined |
boolean |
records
name |
string |
Filter name |
rules |
array[rules] |
system_defined |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
