Create an event filter
Creates an event filter to specify criteria for capturing events based on defined rules. Use this to streamline event monitoring according to your specific requirements.
HTTP method and endpoint
POST /support/ems/filters
Introduced in
ONTAP 9.6
Required properties
name- String that uniquely identifies the filter.
Recommended optional properties
rules- List of criteria which is used to match a filter with an event.
Related ONTAP commands
event filter create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
access_control_role |
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
system_defined |
boolean |
Flag indicating system-defined filters. |
Example request
"access_control_role": {
"name": "admin"
"name": "wafl-critical-events",
"rules": [
"index": 1,
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error",
"snmp_trap_types": "standard,built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
"system_defined": 1
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[records] |
"num_records": 1,
"records": [
"name": "admin"
"rules": [
"index": 1,
"type": "include"
"system_defined": 1
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The filter name provided is empty |
983089 |
The filter name provided cannot contain spaces |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983094 |
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen) |
983095 |
The rule index provided is invalid for the filter provided |
983101 |
No event is matched by the rule provided |
983113 |
Default filters cannot be modified or removed |
983114 |
The maximum number of filters is reached |
983115 |
The maximum number of filter rules is reached |
983126 |
A rule requires at least one name_pattern, severities, snmp_trap_types, or parameter pattern to be defined |
983127 |
A property cannot contain a combination of the wildcard character and other values |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severities provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types properties do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
983195 |
Empty field in parameter_criteria. Both name and value patterns must be specified |
983196 |
name_pattern and value_pattern fields in parameter_criteria are empty |
983211 |
Parameter criteria based filtering is not supported in this version of ONTAP |
href |
string |
_links
access_control_role
name |
string |
Role name |
message_criteria
Matching message definitions for the filter. A property must be specified.
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
rules
Rule for an event filter
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
ems_filter
name |
string |
Filter name |
rules |
array[rules] |
system_defined |
boolean |
records
name |
string |
Filter name |
rules |
array[rules] |
system_defined |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
