Create an event filter
POST /support/ems/filters
Introduced In: 9.6
Creates an event filter.
Required properties
name- String that uniquely identifies the filter.
Recommended optional properties
rules- List of criteria which is used to match a filter with an event.
Related ONTAP commands
event filter create
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
name  |
string  |
Filter name  |
rules  |
array[rules]  |
Array of event filter rules on which to match.  |
Example request
  "name": "snmp-traphost",
  "rules": [
      "index": "1",
      "message_criteria": {
        "name_pattern": "callhome.*",
        "severities": "error,informational",
        "snmp_trap_types": "standard|built_in"
      "type": "include"
Status: 201, Created
num_records  |
integer  |
Number of records  |
records  |
array[records]  |
  "num_records": "3",
  "records": [
      "rules": [
          "index": "1",
          "type": "include"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088  |
The filter name provided is empty  |
983089  |
The filter name provided cannot contain spaces  |
983092  |
The index of the rule provided is outside the allowed range for the filter provided  |
983094  |
The filter name provided is invalid. The filter name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or (underscore). The allowed special characters are (underscore) and -(hyphen)  |
983095  |
The rule index provided is invalid for the filter provided  |
983101  |
No event is matched by the rule provided  |
983113  |
Default filters cannot be modified or removed  |
983114  |
The maximum number of filters is reached  |
983115  |
The maximum number of filter rules is reached  |
983126  |
A rule requires at least one name_pattern, severities, or snmp_trap_types to be defined  |
983127  |
A property cannot contain a combination of the wildcard character and other values  |
983128  |
An invalid value is provided for the property 'snmp_trap_types'  |
983146  |
An invalid value is provided for the property 'severities'  |
983147  |
The severity provided are not supported  |
983155  |
The provided severities property does not match that of the name_pattern  |
983156  |
The provided snmp_trap_types property does not match that of the name_pattern  |
983157  |
The provided severities and snmp_trap_types do not match those of the name_pattern  |
983158  |
The name_pattern provided does not exist  |
href  |
string  |
_links
message_criteria
Matching message definitions for the filter. A property must be specified.
name_pattern  |
string  |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.  |
severities  |
string  |
A comma-separated list of severities or a wildcard.  |
snmp_trap_types  |
string  |
A comma separated list of snmp_trap_types or a wildcard.  |
rules
Rule for an event filter
index  |
integer  |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.  |
message_criteria  |
Matching message definitions for the filter. A property must be specified.  |
type  |
string  |
Rule type  |
ems_filter
name  |
string  |
Filter name  |
rules  |
array[rules]  |
records
name  |
string  |
Filter name  |
rules  |
array[rules]  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
