ONTAP REST API Storage cluster endpoints
Retrieves cluster-wide storage details across the different tiers. Storage details include storage efficiency, block storage and cloud storage information.
Example
Retrieving cluster-wide storage details
The following example shows the details returned for a GET request on cluster-wide storage:
# The API:
/api/storage/cluster
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster" -H "accept: application/hal+json"
# The response:
"efficiency": {
"savings": 143360,
"ratio": 1.134099616858238,
"logical_used": 1212416
"efficiency_without_snapshots": {
"savings": 0,
"ratio": 1,
"logical_used": 167936
"efficiency_without_snapshots_flexclones": {
"savings": 0,
"ratio": 1,
"block_storage": {
"used": 6269812736,
"size": 56125612032,
"available": 49855799296,
"physical_used": 1838284800,
"inactive_data": 0,
"medias": [
"type": "ssd",
"size": 9891430400,
"available": 3728039936,
"used": 6163390464,
"physical_used": 1832886272,
"efficiency": {
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"savings": 0,
"ratio": 1,
"logical_used": 0
"type": "vmdisk",
"size": 46234181632,
"available": 46127759360,
"used": 106422272,
"physical_used": 5398528,
"efficiency": {
"savings": 282624,
"ratio": 1.303964757709251,
"savings": 0,
"ratio": 1,
"savings": 0,
"ratio": 1,
