REST API reference
Manage cluster-wide storage
Retrieves cluster-wide storage details across the different tiers. Storage details include storage efficiency, block storage and cloud storage information.
Example
Retrieving cluster-wide storage details
The following example shows the details returned for a GET request on cluster-wide storage:
# The API:
/api/storage/cluster
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster" -H "accept: application/hal+json"
# The response:
"efficiency": {
  "savings": 143360,
  "ratio": 1.134099616858238,
  "logical_used": 1212416
"efficiency_without_snapshots": {
  "savings": 0,
  "ratio": 1,
  "logical_used": 167936
"efficiency_without_snapshots_flexclones": {
  "savings": 0,
  "ratio": 1,
"block_storage": {
  "used": 6269812736,
  "size": 56125612032,
  "available": 49855799296,
  "physical_used": 1838284800,
  "inactive_data": 0,
  "medias": [
      "type": "ssd",
      "size": 9891430400,
      "available": 3728039936,
      "used": 6163390464,
      "physical_used": 1832886272,
      "efficiency": {
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
        "savings": 0,
        "ratio": 1,
        "logical_used": 0
      "type": "vmdisk",
      "size": 46234181632,
      "available": 46127759360,
      "used": 106422272,
      "physical_used": 5398528,
      "efficiency": {
        "savings": 282624,
        "ratio": 1.303964757709251,
        "savings": 0,
        "ratio": 1,
        "savings": 0,
        "ratio": 1,
