View host records
Use host-record GET endpoints to display the IP address associated with a hostname and retrieve the hostname for a given IP address. These endpoints help you determine network relationships and verify host configurations.
Overview
Displays the IP address of the specified hostname and vice-versa.
Retrieving the host table entries
The host-record GET endpoint to retrieve the hostname for a given Ip address and vice-versa.
Retrieving the hostname for a given IP address.
# The API:
GET /api/name-services/host-record/{svm.uuid}/{host}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/host-record/77e23bd4-a8fe-11eb-99e0-0050568e14ff/127.0.0.1" -H "accept: application/json"
# The response:
"svm": {
"uuid": "77e23bd4-a8fe-11eb-99e0-0050568e14ff",
"name": "svm1"
"host": "127.0.0.1",
"ipv4_addresses": [
"127.0.0.1"
"hostname": "localhost",
"source": "Files"
Retrieving the Ip address for a given hostname.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/host-record/77e23bd4-a8fe-11eb-99e0-0050568e14ff/localhost" -H "accept: application/json"
# The response:
"svm": {
"name": "svm1"
"host": "localhost",
"ipv4_addresses": [
"127.0.0.1"
"ipv6_addresses": [
"::1"
"canonical_name": "localhost",
"source": "Files"
