View host records
Access and display host records by retrieving the IP address for a specified hostname and vice versa. Use these endpoints to manage and query host table entries efficiently within your network environment.
Overview
Displays the IP address of the specified hostname and vice-versa.
Retrieving the host table entries
The host-record GET endpoint to retrieve the hostname for a given Ip address and vice-versa.
Retrieving the hostname for a given IP address.
# The API:
GET /api/name-services/host-record/{svm.uuid}/{host}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/host-record/77e23bd4-a8fe-11eb-99e0-0050568e14ff/127.0.0.1" -H "accept: application/json"
# The response:
"svm": {
"uuid": "77e23bd4-a8fe-11eb-99e0-0050568e14ff",
"name": "svm1"
"host": "127.0.0.1",
"ipv4_addresses": [
"127.0.0.1"
"hostname": "localhost",
"source": "Files"
Retrieving the Ip address for a given hostname.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/host-record/77e23bd4-a8fe-11eb-99e0-0050568e14ff/localhost" -H "accept: application/json"
# The response:
"svm": {
"name": "svm1"
"host": "localhost",
"ipv4_addresses": [
"127.0.0.1"
"ipv6_addresses": [
"::1"
"canonical_name": "localhost",
"source": "Files"
